Old 08-02-2007   #1 (permalink)
Removing rivets
Alright, this may be a dumb question, but what is the best way to remove a rivet?? I just recieved my Mivv exhaust and want to remove the baffle. Thanks for any help.
warped929RR is offline   Reply With Quote
Old 08-02-2007   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Drill the heads off then push them into the can (the drill will probably do this in the same action)
Just don't go too big on the drill size - you don't want to enlarge the hole.
GSXR 1000 Front End Swap
Old 08-02-2007   #3 (permalink)
Spooner's Avatar
+1 easy peasy
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 08-02-2007   #4 (permalink)
Thanks guys.
Old 08-03-2007   #5 (permalink)
It might be a good idea, to put some masking tape or duct tape around the area your going to do the drilling to protect the skin of the pipe. The chances of the drill sliding off is pretty good.
hooliganmech is offline   Reply With Quote
Old 08-03-2007   #6 (permalink)
where did you get your mivv?
hooliganrider is offline   Reply With Quote
Old 08-03-2007   #7 (permalink)
hooligans--funny you bring that up, with the tape. The drill did slip and I put a small scratch on the end of the pipe, good call, but a bit too late--oh well. I got the Mivv from PJsParts.
Removing AI intrusive1 Twins Technical Talk 23 03-31-2008 05:25 AM
Exhaust Can Rivets Fridgehq Modifications & Workshop Talk 1 01-22-2008 09:59 AM
Plastic rivets Zed Triumph SuperSports 6 05-04-2007 10:22 AM
Removing the AI rabbid Club Cafe 2 09-07-2006 10:15 AM
Brake rotor rivets loose, clickity click click. Skyler Speed Triple Forum 4 07-26-2006 02:04 AM
