» Links |
07-11-2007
hey up fellas
i have a 2006 speed triple 1050 im working on for a customer and it has a intermittant cutting out problem,on a lot of the earlyer bikes the ignition pick up coil fails quite often and ive replaced a lot of those,i was wondering if anyone with the 1050 has had problems with that unit?or is there any other common failed electrical componant that you know of?
cheers
adrian
www.adepackett.com
SPEED?.....its all a question of money............................................. .,HOW FAST DO YA WANNA GO?
also does anybody have the spec for the resistance reading on the pick up coil?the one on this bike reads 642 ohms when hot and the bike is failed ?
07-12-2007
Powerbike Favorite Bike: 2006 Triumph Speed Triple
Posts: 331 Other Motorcycle: 2003 Triumph Speedmaster
Hey Adepackett - Can't say I have any specific knowledge on this area, but I do have just a general observation/question along the same lines:
Does anyone else think that the fact that the '05 & '06 Speed Triples have to be cranked 2-3 times (at length) just to start would seem to stress the ignition, battery and electrical system more than is healthy? And potentially lead to premature ignition coil failures down the line?
My .02...
-CT
2006 Speed Triple - Fusion White / Pazzo/Rizoma/K&N/LSL/Motovation/Micron CF Race Cans
2003 Speedmaster - Red & Black / 125/42 Jets/AI Removed/K&N /17T Sprocket/Custom Straight Pipes/Ceramic-Coated Headers
07-12-2007
SuperStock Favorite Bike: Speed Triple
I doubt that having to crank the bike a couple times or seconds stresses the electrical system other than putting more wear on the starter motor.
My last 2 bikes were Yamaha FZ-1s and it always was a hard to start bike when cold. One of my FZ's had 40,000 miles and the other 20,00 and the starters never failed.
07-12-2007
The pickup coil resistance spec is 560 ohms +/-10% at 20 degrees C. 640 ohms hot does not sound too high depending on how hot you are talking about.
07-12-2007
ahhhh
thanks for that resistance figure,it appears the coil is ok at this point,where did you find that info if you dont mind me asking?triumph figures are hard to track down sometimes......
all 7of the 1050s i work on have the delay in starting,i dont think its a issue myself as long as it fires,its not gonna hurt anything......
adrian
www.adepackett.com
07-12-2007
Yes, BigRedandRiding, I agree, the stock battery is good, but inadequate to the bike. I am searching for a better battery.
07-12-2007
Grand Prix 125 Favorite Bike: 05 Speed3
I was wondering what you mean by the cut out problem? Reason I ask is that just today when I was going to work I left my garage (after that 3 sec ignition crank as always.) and rode down the block just fine. As I approached a stop sign I clutched in and let off the throttle and it stalled/died. Cranked it up for a few seconds and it fired up and stalled again like it had no idle at all. I rode it home ok but I had to hold the throttle open a little to keep it from stalling.
Would that be similar to the cutting out of the ignition you are speaking of?
07-12-2007
I've heard of the engine kill swithc having intermittant shorts or defective connections that turn the engine off suddenly. Loose/shoddy connections within the housing.
I've also heard of the switch at the kickstand going all wacky as well which would shut th eengine off.
Check those switches yet?
While you're at it, test the tip over kill switch if this bike has one.
Good luck!
07-13-2007
Switch at kickstand? I can start mine with the stand up. '06. Am I not supposed to?
