BikeBandit
Old 05-03-2008   #81 (permalink)
Originally Posted by indi1050 View Post
Cheers for your reply - Just making sure I understand - with the baffles in, it doesn't need to be retuned (the standard stock tune is ok) but with the baffles out, to get the optimum performance it should be retuned.
Yes, that's my take. The Arrow duals with noisekillers in are closer to stock cans than to any performance mufflers -> the stock tune is the closest match. That is assuming the factory has not produced a new ECU tune, that is specificly made for the Arrow duals. I have not seen such a tune.
With the noisekillers out the cans become like any other straight through aftermarket cans and then the TOR map would be the official choice. Many have also had good results on using the Arrow full system tune with just a muffler change.
Martin_R is offline   Reply With Quote
Old 05-07-2008   #82 (permalink)
Favorite Bike: Speed Triple 1050i
Chain Reaction Velocity GP
Mini4x is offline   Reply With Quote
Old 05-07-2008   #83 (permalink)
OK, I'm confused now after reading through this thread. I recently bought an '07 new, and it has VIN 289***. It seems to have the '07 ECU (makes fax machine noises after shutoff), but it has the O2 sensor threaded in next to the oil filter. Is this an '06 or '07 exhaust? It has the big bulky heat shield at the back where it splits back into 2 pipes, like the '08s, but I don't know if the earlier years had that, too. Just trying to figure out which model year exhaust to order from.
Will the Arrow 3-1 full system work on all model years? Which O2 sensor location is the bung welded for on that system? Thanks for the help.
RampageS3 is offline   Reply With Quote
Old 05-07-2008   #84 (permalink)
Favorite Bike: 07 Speed Triple
nodrog's Avatar
Originally Posted by RampageS3 View Post
....... but it has the O2 sensor threaded in next to the oil filter. Is this an '06 or '07 exhaust? It has the big bulky heat shield at the back where it splits back into 2 pipes, .....
sounds like you have an '07 exhaust to me
nodrog is offline   Reply With Quote
Old 05-07-2008   #85 (permalink)
sonnyboy11's Avatar
Bulky heatshield = you have an 07+ exhaust config.
sonnyboy11 is offline   Reply With Quote
Old 05-08-2008   #86 (permalink)
Thanks for the replies. So does this affect the fitment of the Arrow 3 into 1 system? Would my O2 sensor location require cutting and lengthening wires to mount it into the Arrow system? Again, mine is right next to the oil filter. Thanks.
Old 05-12-2008   #87 (permalink)
Question?
I just installed the new Arrow 3 to 2 silencers from Triumph on my 2005 speed triple.
They look great, fit and finnish is very impressive. I would like to remove the baffles (or whatever they are called) to get the full sound out of them. What is the best way to remove them?
brit3 is offline   Reply With Quote
Old 05-12-2008   #88 (permalink)
Favorite Bike: 2007 Speed Triple
Other Motorcycle: 1986 Honda XL250R
I just used a dremel and ground off the little tab that sits between the circlips. After that is gone, remove the circlips and pull the baffles out.
bobmcduff is offline   Reply With Quote
Old 05-12-2008   #89 (permalink)
Answer
THANK you for all who would have replied, i found this (THE ANSWER) on the web. thank you indi1050 if you post here also, great demo.
Old 05-12-2008   #90 (permalink)
I used a small carpenter's chisel + mallet on the tabs. They are just barely welded on. I'd imagine they are just there to please some emission standard board somewhere, and people at Arrow know everyone is going to whack them out anyway.
An Exhaust Thread HandleOnTheRight Street Triple Forum 7 11-21-2007 06:41 PM
another jetting/exhaust thread Buford_VMI86 Twins Technical Talk 20 08-21-2007 12:02 AM
Exhaust thread SP4invista Triumph SuperSports 3 07-24-2006 10:37 PM
Speed Four Exhaust Thread! xsquiggy Triumph SuperSports 27 07-09-2006 08:15 PM
Exhaust Audio Thread HooliganRandy Triumph SuperSports 7 06-10-2006 07:24 AM
