» Log in
User Name Not a member yet?
Register Now!
  #81 (permalink)
Old 2 Weeks Ago
DEcosse's Avatar
Originally Posted by Moogs View Post
...Tune needed: Arrow tune from dealer or Tuneboy tunes 20133, 20134, 20131, 20132, 20181, or 20182 depending on VIN# and other mods.....
The tunes are not actually 'Tuneboy tunes', those are the OEM Triumph tune ID's. Tuneboy conveniently hosts them all so you can conveniently access them if you have the Tuneboy tool to load them onto your bike.
For the tunes you listed by number, for example 20182 is described as " 1050 Speed Triple with Arrow pipe; Without secondary air injection; From VIN 305060 (Steel fuel tank) Which is exact same descriptor as the 20209 file!
(20209 is obviously a later tune - has it replaced 20182 as the 'std' option?) Might need to ask dealer about that.
GSXR 1000 Front End Swap
  #82 (permalink)
Old 1 Week Ago
indi1050's Avatar
How do I check whether my ECU has been retuned?
I have recently had some Arrow Slip ons fitted by a Triumph dealer - sound sweet.
Anyway, whether the baffles are in or out, the engine doesn't seem as powerful as it was, especially top end (this maybe my imagination thou).
1. Is there a simple way I can confirm whether the engine has been retune or is it something the dealer needs to confirm?
2. Also, I assume that any retune will optimise the performance whether the baffles are in or out?
  #83 (permalink)
Old 1 Week Ago
You need TuneBoy or dealer tool to check current ECU tune.
No "race" tunes for the baffles-in, except for the stock one your bike came with.
I'd take baffles out and have dealer upload TOR or Arrow full system tune.
The whole thing is much simpler than a proper custom tune for your individual bike. The dealer just has a handfull of factory provided fuel & ignition maps and they pick the closest match for your bike configuration.
  #84 (permalink)
Old 1 Week Ago
indi1050's Avatar
Cheers for your reply - Just making sure I understand - with the baffles in, it doesn't need to be retuned (the standard stock tune is ok) but with the baffles out, to get the optimum performance it should be retuned.
  #85 (permalink)
Old 1 Week Ago
Yes, that's my take. The Arrow duals with noisekillers in are closer to stock cans than to any performance mufflers -> the stock tune is the closest match. That is assuming the factory has not produced a new ECU tune, that is specificly made for the Arrow duals. I have not seen such a tune.
With the noisekillers out the cans become like any other straight through aftermarket cans and then the TOR map would be the official choice. Many have also had good results on using the Arrow full system tune with just a muffler change.
  #86 (permalink)
Old 1 Week Ago
Send a message via AIM to Mini4x
Chain Reaction Velocity GP
  #87 (permalink)
Old 1 Week Ago
OK, I'm confused now after reading through this thread. I recently bought an '07 new, and it has VIN 289***. It seems to have the '07 ECU (makes fax machine noises after shutoff), but it has the O2 sensor threaded in next to the oil filter. Is this an '06 or '07 exhaust? It has the big bulky heat shield at the back where it splits back into 2 pipes, like the '08s, but I don't know if the earlier years had that, too. Just trying to figure out which model year exhaust to order from.
Will the Arrow 3-1 full system work on all model years? Which O2 sensor location is the bung welded for on that system? Thanks for the help.
  #88 (permalink)
Old 1 Week Ago
nodrog's Avatar
Favorite Bike: 07 Speed Triple
Originally Posted by RampageS3 View Post
....... but it has the O2 sensor threaded in next to the oil filter. Is this an '06 or '07 exhaust? It has the big bulky heat shield at the back where it splits back into 2 pipes, .....
sounds like you have an '07 exhaust to me
  #89 (permalink)
Old 1 Week Ago
sonnyboy11's Avatar
Bulky heatshield = you have an 07+ exhaust config.
  #90 (permalink)
Old 1 Week Ago
Thanks for the replies. So does this affect the fitment of the Arrow 3 into 1 system? Would my O2 sensor location require cutting and lengthening wires to mount it into the Arrow system? Again, mine is right next to the oil filter. Thanks.
An Exhaust Thread HandleOnTheRight Street Triple Forum 7 11-21-2007 05:41 PM
another jetting/exhaust thread Buford_VMI86 Twins Technical Talk 20 08-20-2007 11:02 PM
Exhaust thread SP4invista Triumph SuperSports 3 07-24-2006 09:37 PM
Speed Four Exhaust Thread! xsquiggy Triumph SuperSports 27 07-09-2006 07:15 PM
Exhaust Audio Thread HooliganRandy Triumph SuperSports 7 06-10-2006 06:24 AM
