Originally Posted by brit3
I removed them after taking the weld off and I rode for a while last night. A couple of things I noticed.
1) from idle to around 3k rpm there isn't a huge difference in the noise under load
2) over 3k rpm it is lower and louder by a noticable amount (your right the video doesn't do it justice.
3) once you are in high gear and back around 3-5k rpm (highway speeds) you do get a droning that isn't as loud stock.
4) if you run it without the baffles you need the remap.
Personally I like the sounds that come from that monster when the baffles are out. The first light i hit when i got off the twisties there was a car full of girls that were like NICE BIKE and they started yelling and stuff. that could have had something to do with it... love the triple
Whether I run mine baffles in or out, ever since the Arrows have been fitted I get an annoying clatter/loose noise at certain revs/speed - generally 18-60mph when just jogging along without putting on the power - as soon as you power up it is not so noticable.
It's been back to the dealer who says it is exhaust resonance & confirm that they did retuned it when the Arrows were fitted and say it is just one of those things.
To get a comparison, I took out their test bike which has the same Arrows and it didn't clatter and popped far more on decel.
Is it usual 1) the clatter/exhaust resonance, 2) different S3 different exhaust effects - Any ideas?
