I had the same issue but my lines were correct, I straightened out check valveto vertical and gave it a tap to free the possible stuck valve, All is well.
Others have simply removed the check valve, If I have the issue again, It will be removed.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
