Motorcycle.comTrident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
Old 06-22-2007   #1 (permalink)
I'm putting on the LSL Sliders and I was wondering if someone could tell me the size of the bolt/nut on the back of the right side (the nut opposite the right-hand side 55 torx bolt).
Also, are there SAE bolts on the speedy or all metric?
And, yes, I will buy the service manual.
Thanks
wookie is offline   Reply With Quote
Old 06-23-2007   #2 (permalink)
I think its a 17 mm. If your takin the front bolts out it helps to take out the radiator bolts (only four 8 mm) out to give a little extra room.
hooliganrider is offline   Reply With Quote
What size bolts - grab rail? BishRat Twins Technical Talk 2 11-29-2007 08:51 AM
Looking for custom size bolts tri650 Modifications & Workshop Talk 6 12-21-2006 06:26 PM
Black bolts for passenger peg mount holes? flyboy Speed Triple Forum 2 07-17-2006 06:52 PM
Size of Fork Cap Bolts wenzel850 Twins Talk 3 03-10-2006 12:47 PM
Mirror Mount Size for 1050s3 redwhiteblue Speed Triple Forum 1 09-30-2005 09:14 PM
