Trident-Exhausts.comBikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 06-22-2007   #1 (permalink)
I'm needing to replace my weak battery and all the agm and sealed types have the polarity arse backwards of mine, where as the negative is on the left (or rear brake side).
has anyone found one that is right for the 97 S3 or can you use the other reversed polarity ? And did the leads reach ? My neg looks to be short, not sure of pos.
rckrzy1 is offline   Reply With Quote
Old 06-23-2007   #2 (permalink)
www.batterystuff.com
They've got your battery. I mistakenly got your battery when I tried to order one for mine ('98). Turns out mine uses the later model with the poles reversed....the one that WON'T work on yours :-D
Ride it, break it, fix it, repeat.....
Helmet_Hair is offline   Reply With Quote
My NEW Sealed Battery Came!! John21 Biker Hang-Out 5 12-06-2007 03:53 PM
Sealed Battery? T-Mac Hinckley Classic Triples 7 08-04-2007 07:05 PM
Sealed battery test ? Normandy Twins Talk 5 06-20-2007 11:39 PM
Is the "Bonnie Battery AGM or Gel Cell? Stealthrider Twins Talk 3 08-19-2005 11:28 AM
Sealed Battery Beemie Hinckley Classic Triples 7 03-29-2005 02:50 PM
