As I mentioned in an earlier post I recently swapped the stock 1/4 turn throttle tube for a 1/5th turn. Well, tonight I took Speedy out for her first test ride with the new gear and the difference was noticeable. Firstly, acceleration was slightly easier due to the shorter throw and WOT came sooner. This made it feel faster (while of course it wasn't) because smaller throttle inputs caused greater acceleration. On the down side, bumps in the road and other jolts had a bigger affect as the throttle hand gets jostled around a bit, ...that will take a little time to get used to and to get under control. Other than that I would say it was a good upgrade, especially when I go to the track, I won't have to stretch so far to get the throttle open.
