Did you try the brake with the ignition on? Unlike a car, the light doesn't work if the key is off.
If it still doesn't work, try unplugging the brake light and checking the circuit with a volt/ohm meter. Take the tester and plug a lead into each wire going into the brake light with the tester set for continuity. If it tests good, then check for voltage coming to the light. Of course, if you show open circuit on the light, the bulb is burnt.
Enjoying the naked life.
