Old 06-11-2007   #1 (permalink)
Promised I'd do a thread on putting a pair of Brembos on my 06 Speedy, so here we go. Bought a pair of "Brembo HP Billet series" from:
Jeff Gehrs
BrakeTech USA, Inc.
Ph: 951-471-3476
Fax: 951-471-3536
www.braketech.com
I hate the way my stock Nissins feel. I have not had (yet) the lever-to-the-bar experience, but the "progressive" feel, feels like *****. Really not confidence inspiring, especially knowing their history of failure and the lack of a convincing fix.
Jeff had them in stock along with mounting bolts and spacers. This is a swap he does for Japanese bikes a lot, but this was his first Speed Triple so we had to experiment a bit and Jeff as very helpful and, as a result, now has the "definitive" Speed Triple kit (for the '06 at any rate). Yes, it's now plug & play.
Observations: When you pull off your Nissin calipers you can see that the calipers are recessed to accept a grooved spacer — but the mount on your lower fork is not. So, Jeff has black spacers the right size that come without the inserted aluminum dowel designed for the double recessed setup. Jeff originally sent a bunch of spacers down to me to experiment with, but only the correct sized (black) spacers with the dowel. It was the weekend and I didn't want to wait for the correct set, so I took a file and ground off the dowel at one end. Thus one side fits into the recessed area on the Brembo, the other lays flat against the flat face of the mounting bracket. Jeff has the spacers without dowel inserts.
Next you will notice the mounting bolts from your Nissins will not work with the Brembos. The threaded diameter and non-threaded are different diameters. And, I must admit I was offended by the lame "manufacturing" process used to created the Triumph stock bolt. Apparently they don't fit at the factory, either, so they cut off the ends with what looks like a hydraulic bolt cutter! Anything to avoid the extra cost of a spacer, I guess. Again, Jeff has very nice bolts (not cut off) that fit perfectly with the spacer.
Your banjo bolt from the Nissins will not fit the Brembos, but replacements that come with the Brembos fit the stock Triumph hose fitting no sweat. You will have to do what Triumph did on their Nissin setup, which is swap the bleed fitting and the hose fitting. Otherwise the hose isn't long enough, and, wouldn’t be on the stock set up either.
Ok, for those of you who have never done this before, you will need:
12 mm wrench to take off Nissin mounting bolts.
8 mm Allen/socket for putting on new mounting bolts.
14 mm socket (wrench) for banjo bolts.
11 mm for bleed bolt.
Torque wrench
3/8" clear hose for bleeding. Also I use a syringe from an equine supply with a piece of aquarium air line hose inside the 3/8 to force brake fluid back up from the caliper to the master. What do they drive like? Better than night and day. Cost? With shipping + tax (I live in California so must pay 8.25%) = $1689.06. I know there are cheaper ways to go by adapting a different front end. But when I figure my time is worth much more so this is not only the best way for me to go, but the cheapest. Besides, the Speedy is such a good deal out the door, adding this for great brakes still doesn't seem like much to me.
[ This message was edited by: scrannel on 2007-06-11 13:38 ]
scrannel is offline   Reply With Quote
Old 06-11-2007   #2 (permalink)
Dax
Beautiful....
Brembos are the best in my opinion!!
Dax is offline   Reply With Quote
Old 06-11-2007   #3 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS
Extra Motorcycle: TT600 - Spongebob
Way outta my tax bracket, but if you kin afford it, :chug:
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 06-11-2007   #4 (permalink)
stock master cylinder or brembo radial ?
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Old 06-11-2007   #5 (permalink)
Stock master. I wanted to see if the issue was indeed just the calipers and this seems to be the case. Stock master works great. I guess it always did.
Old 06-11-2007   #6 (permalink)
Favorite Bike: Ducati 916-996-998-1098
Max_NYC's Avatar
Other Motorcycle: Triumph Speed Triple
Now add the Ohlins at the rear!
"Je penche, donc je suis."
Max_NYC is offline   Reply With Quote
Old 06-11-2007   #7 (permalink)
Max_NYC's Avatar
The stock Nissin is that bad on the new S3? Or did you have one of the early '06's (VIN#<253302) with the mushy front brake?
Old 06-11-2007   #8 (permalink)
My vin: 251690... so... however I have not experienced the melt down everyone complains of, but from day one did not like the mushiness of my Nissins. After install of Brembos, pushed S3 out to driveway, hit front brake to stop and almost dropped the bike -- the difference is that pronounced. This is now truly a different bike.
Old 06-11-2007   #9 (permalink)
Mizterpink's Avatar
if they have Brembo brakes at the link you gave us www.braketech.com. they make it very difficult to find much more than pads and discs.... I can't find the brakes you got
Blow it out your arse :P
http://i197.photobucket.com/albums/a..._full2inch.jpg
Mizterpink is offline   Reply With Quote
Old 06-11-2007   #10 (permalink)
What's the cost? Some of these guy spend hundreds on new pipes and things, so I'm curious how this compares.
Brakes are for people who ride slow.
Euro is offline   Reply With Quote
Is the signalminder from New Bonneville plug-and-play? Ready to Ride Twins Technical Talk 34 04-24-2008 09:09 PM
Plug and play alarms superfour Tiger Workshop 3 02-18-2008 06:23 PM
Brembos on the Limited Edition? Spooner Speed Triple Forum 14 05-05-2007 02:11 AM
Can I Play Too? nexus_7 Twins Technical Talk 3 03-09-2007 08:29 PM
Is Tuneboy plug and play yet??? Pig9r The Rocket Science Forum 10 12-05-2006 08:52 AM
