Trident-Exhausts.comBikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 06-09-2007   #1 (permalink)
Hi guys,
I know this was covered b4 but my search ended without success. Started bike twice to show off new Zard! Of course I didn't ride it (I know I should have!) and now it laughs at me when I try to start it to go for a ride. What do I have to do? Just wait or is there a magic trick? HELP
Its all Fun & Games untl someone loses an eye.
Yandicoogina is offline   Reply With Quote
Old 06-09-2007   #2 (permalink)
Favorite Bike: 01 Legend TT!
Other Motorcycle: 04 Buell XB12S
Extra Motorcycle: 01 HD XLH883
Change the spark plugs - you have probably fouled them and the bike likely won't start without a fresh set. Never, ever, fire up a Triumph fuel injected bike rev it a couple of times and shut it off. These bikes run very rich on start up and need to run for a bit before shutting down - if you don't - the result is fouled plugs
BrentCross is offline   Reply With Quote
Old 06-09-2007   #3 (permalink)
Yeah I remember reading that now! Lesson learned.
All because I wanted to show off the 'flaming exhaust'.
Ooops.
Old 06-09-2007   #4 (permalink)
Charge your battery. It could be that its low. It takes something like 15 minutes of riding to recharge just from a single start.
Old 06-09-2007   #5 (permalink)
Favorite Bike: '05 Speed triple
crudmop's Avatar
Other Motorcycle: Current Collection:
Extra Motorcycle: 01 996 -03 636 -98RS 250
When you start, does it sound like it's getting compression?
crudmop is offline   Reply With Quote
Old 06-09-2007   #6 (permalink)
It was turning over, just not firing. Tried 6 times over an hour and now battery is struggling. I will chase up new plugs on Mon morning. Cheers
Old 06-09-2007   #7 (permalink)
crudmop's Avatar
FYI - if you wash down the cylinders (flood it trying to get it started), there was an earlier software version that would sense this, assume it meant there was a lack of compression and shut off the ignition - the only way to trick it back into firing again is to squirt a little oil into each cylinder.
There's a software update to correct this problem, but you'll have to ask your dealer to apply it. Normally, they'll have to call Triumph service to get the info. I was under the impression it only affected the 05's, but as the 06's rolled out at the end of summer '05, you might be prone to the same error.
If it's shut off the ignition system, when you crank it you'll hear a bit of a chirp, and it will sound like it's not getting any compression.
Hard starting / starting fluid TailHooker Hinckley Classic Triples 20 09-01-2007 12:39 PM
Starting over again. hillclimber Classic, Vintage & Veteran 10 11-19-2005 12:08 PM
STARTING andy237 Hinckley Classic Triples 2 11-17-2005 11:11 AM
Not starting Henski Tiger Chat 3 06-14-2005 06:37 PM
HELP...NOT STARTING Sport Sprint Forum 3 03-22-2005 09:53 AM
