Old 06-07-2007   #1 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
So, I want narrower bars, which would be pretty straightforward except that there are inserts about an inch and a half into the inside of each bar. This makes it tough to use bar-end mirrors without some McGuyvering - I'd have to find some sort of different sized rubber bushings for the Napoleons.
So, has anybody removed these? Are they just spot-welded in? Can it be done? Or maybe someone has found a workaround.
Or should I just spend the $60+ for aftermarket bars and hack those?
[ This message was edited by: R100Pilot on 2007-06-07 09:16 ]
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 06-07-2007   #2 (permalink)
Go someplace like cyclegear and get a bar, and hack away. That way, you've still got the stock bar in case you decide to go back. You may know somebody with a spare moto-style bar in their garage that you can get cheap, too.
Enjoying the naked life.
BillT is offline   Reply With Quote
Old 06-07-2007   #3 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
Plus, aluminum bars are much easier to hack.
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
Old 06-07-2007   #4 (permalink)
R100Pilot's Avatar
Y'all are just _tryin'_ to get me to spend more money, ain'tcha :-D
— HST
Old 06-07-2007   #5 (permalink)
Goffe's Avatar
Well, you are the one buying nuts for your mirror stalks.
Old 06-07-2007   #6 (permalink)
R100Pilot's Avatar
True. But they are damm fine nuts! :hammer:
So do I go with gold, black, or natural bars? Or just spring for clip-ons. Hmm...
— HST
Old 06-07-2007   #7 (permalink)
Favorite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '07 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
I followed these instructions for installing Napoleons on my wife's TBS, and it worked out great.
http://www.webbikeworld.com/tbird/mirror/mirrors.htm
Alternatively, remove the rubber grommet from the mirrors, and take a hacksaw to the protruding plastic, making the bar-side flush. Then use the original bar-end screw to bolt it all together.
Me, on the other hand, am going to spend some bucks and pick up a spare of Rizoma Reverse Retros.
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline   Reply With Quote
Old 06-11-2007   #8 (permalink)
I think the bar actually gets thicker 1.5" in from the ends, so (obviously) it would be difficult to remove the shoulder. Why not just cut the Napoleons' existing bushings down a bit? I did that after I installed in-bar grip heaters and it worked fine.
Curmudgeon is offline   Reply With Quote
Old 06-11-2007   #9 (permalink)
R100Pilot's Avatar
Bein' a cheapbastard, I think I'm gonna try an' bodge somethin' up with the stock bars. NinjaRAT and Curmudgeon, if it works, I'll buy y'all a Guinness (one each, of course) with the money I save.
:-g
If that fails utterly, y'all get no beer, and I'll probably go with Renthal streetfighters or Pro Tek clip-ons (if I'm feeling half my age).
— HST
Old 06-11-2007   #10 (permalink)
NinjaRAT's Avatar
Now that I've an opportunity to inspect my '07 closer, it looks as if Napoleans would fit just fine. Had to have the dealer show me the trick about removing the bar-ends, but they appear to be wide open, once the bar-end is removed.
Did this change between the '06 and '07? Hope I'm not mising something, because I have a pair of Napoleans on order.
Need handlebar ends for Pro-Taper handlebar Aurelius Speed Triple Forum 2 10-20-2007 11:38 PM
handlebar vibration Bigman Twins Technical Talk 6 06-10-2007 02:06 PM
2006 t3 peg and handlebar mods vendman Speed Triple Forum 8 08-17-2006 09:09 PM
Handlebar buzz Panthermark Twins Talk 15 04-08-2006 11:32 AM
some handlebar (and other) questions mdglaw The Rocket Science Forum 6 06-10-2005 06:40 PM
