Old 06-05-2007   #1 (permalink)
Mizterpink's Avatar
anyone have the Rizoma - Conical 29-22mm Handlebars?
I have a couple questions for people who have them....
1. are they wider than the stock bars? if they are how much?
2. how do they feel compared to stock bars?
less vibration? farther reach? straighter than stock? how do they feel on your wrists?
3. with the 40mm riser (if you have the 40mm) does that put the bars at about the same height as stock?
4. if you have CRG bar end mirrors. how did they fit in the end of the bar? did you need any type of adapter?
I love the feel of the stock bars now after screwing around with a different riser. it made me realize the stock set up is pretty ***** good for me. so I'm hoping the Rizomas aren't going to be a big change in feel. Why bother you ask? cuz i want black bars and risers but don't want to have my bike apart for a couple weeks while i get the stock stuff powder coated, and the wider black Triumph bars are actually more expensive..
+ the rizoma pimp factor. they just look nicer
[ This message was edited by: Mizterpink on 2007-06-05 18:11 ]
Blow it out your arse :P
http://i197.photobucket.com/albums/a..._full2inch.jpg
Mizterpink is offline   Reply With Quote
Rizoma Conical Signals and Suggestions for a Brake Light idaho_thrux Twins Technical Talk 11 11-21-2007 11:36 PM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
Conical frontbrake vs disc brake happyray Classic, Vintage & Veteran 36 02-21-2007 06:00 PM
Rizoma road_dog Twins Technical Talk 5 02-05-2007 11:04 PM
Rizoma sevrin Speed Triple Forum 5 07-13-2006 09:52 AM
