you will have to get a pre-02 hanger for the pipe, the 03-later has different "recesses" that prevent the spacers from fitting properly. Even with the older hanger the peg still rubbed the can. I ended up making my own spacers from aluminum round stock. If you have access to a machine shop its a piece of cake on the lathe and you can make them the right length (and probly work with the 04 hanger).
Chris
Custom undertail exhaust, ceramic coated black, black powder coated headlight buckets and radiator shrouds, Cateye mirrors, Pazzo shorty levers.
