Old 05-19-2007   #1 (permalink)
ANY BODY COULD GIVE ME THE STEPS TO INSTAL AN AFTER MARKET AIR FILTER
THANKS
ARNAUD
nono54 is offline   Reply With Quote
Old 05-20-2007   #2 (permalink)
S_Mues's Avatar
If it's anything like a 03 remove tank see the air box (Big black box with scoops on top) remove all the screws holding it together (don't forget the one right in the middle). Simply remove the stocker and place in the new one. Reverse steps to assemble and enjoy. Not sure but a remap may be necessary hopefully some one will chime in. Hope this helps.
Speed is like a Legal Drug (Almost).
S_Mues is offline   Reply With Quote
Old 05-20-2007   #3 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
That's basically it. Also, don't mix up the two small black hoses that come straight down from the tank. The one with the box goes nearer the center of the tank (I think). You also have to disconnect the fuel line and the fuel pump electrical connector. Keep the tank relatively level and only a drip or two of gas will come out. Note: The K&N may not fit quite right. Make sure the sides are straight. You will have to remove the thin rubber gasket from the stock filter and fit it to the K&N. This is what mine looked like, and I sent it in for replacement:
[ This message was edited by: Goffe on 2007-05-20 18:49 ]
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
K & N Air Filter Trotts Tiger Workshop 24 09-18-2007 08:39 PM
air filter wildchild Twins Technical Talk 1 06-08-2007 10:04 PM
uni verses KandN air filter air flow rays323929 Twins Technical Talk 3 01-31-2007 04:09 PM
K@N air filter on 95 s3 leggos T3 Sport / Touring Forum 1 12-19-2006 07:34 AM
Air Filter sco Hinckley Classic Triples 4 07-25-2006 01:16 PM
