ShopTriumph.com
Old 05-13-2007   #1 (permalink)
Anyone got a good map for a 2007 ECU S3 with a Zard, I had the TOR tune put in the bike but it still backfires on trailing throttle. Less than before though. Also seems to be running way rich on WOT, guys behind me complaining of getting mouth fulls of black smoke :-)
Another whinge is that when the throttle is closed say under heavy braking before going into a roundabout, then when I open the throttle again the power does not come on smooth at all, it's like it's at 5 or 10% throttle instantly, makes the bike a bit wobbly coming on power like that when your cranked over..
Anyone else have the same experience?
Cheers
Trumpy1050 is offline   Reply With Quote
Old 05-13-2007   #2 (permalink)
You'll probably have to get Tuneboy or a Power Commander for proper mapping. There are maps available for them.
littlefield is offline   Reply With Quote
stock map or tors map after exhaust upgrade? tekmoe Speed Triple Forum 6 07-15-2006 11:21 AM
Tuneboy with Trident exhaust slipon. What map? Granitsky Speed Triple Forum 4 05-05-2006 11:24 PM
Another dumb tuneboy/fuel injection map question... MercuryMan76 Triumph SuperSports 3 04-11-2006 11:56 AM
New Scorpion exhaust,TOR map or Tuneboy? Mullethead Daytona Deliberations 4 02-20-2006 07:52 PM
