Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 04-22-2007   #1 (permalink)
Just for the record, i am no mechanical, torque/horsepower curve, numbers genious. Just an average rider who's had plenty of seat time on an 01 CBR 929RR and other various 600cc sportbikes and a proud new owner of an S3. I know comparing these two bikes is like comparing apples to oranges and that they are in two different classes, but I thought it would be fun to compare anyway.
I'll start by the gears:
My S3 has about 380 miles on the clock now and i'm starting to test the water in the higher rpm range.
I'm still breaking the bike in, but I decided it was time to see what the S3 had to offer in 1st gear. I ran it up to 10,000rpm and it was fast, but it didn't have that "fly off the back of the seat" pull that the 929 had. Now, I will be honest, I was hoping it would be close to having that hard pull that the 929 has and this isn't a bad thing that it doesn't, because it is still quite fast. Now i'm thinking to my self, "this power has to be somewhere??" So at around 4000 rpm, still in 1st gear, I blipped the throttle, and sure enough the front end came up about six inches with ease. Now this could be done on the 929, but I had to let off the throttle and then twist the throttle quick to get the front end to come up @ 4000 rpm, and it didn't work for me all of the time neither. So now I drop to 2000 rpm on the S3 and hit the throttle hard and the front end comes right up again with ease. I definitely couldn't do this on the 929 at that low of rpm. It could be done with the clutch, but i'm too much of a sally for that. The S3 is a torque monster!
Now in 2nd and 3rd gear, the S3 pulls harder, still not as hard as the 929, but it's enough to get me warm and fuzzy on the inside. However, on the S3, at around 7-8000 rpm, in 2nd gear, you get that "fly off the back of your seat" pull, which was very fun. I wasn't able to see if 3rd or 4th had that same feel in the higher rpm range because I ran out of road . I would bet, that with a little practice or just a big handful of throttle, that a rider could power wheelie in 2nd gear. I didn't try it because i'm still getting used to the feel of the S3 and i'm also not that great at wheelies.
Here is one of my most favorite things about the S3 compared to the 929: There is roll-on power in just about every gear. I don't have to down shift when I want a power boost like I did on the 929, trying to get the higher rpms for the power. Of course, when you downshifted on the 929, you get the ultimate adrenaline rush of speed. Also, I don't think i'll have to use 6th gear very much on the S3, unless your going really fast.
Suspension and handling-
I don't know much about suspension tuning. My S3 is set to stock and as far as I know, my 929 was also. The 929 was excellent when it came to handling. It was very flickable, due to the fact that I dropped from a 190 rear tire to a 180 rear tire. The 190 seemed like I had to muscle the bike in every turn. The 180 made handling so much easier. The S3 also has a 180 on the back and it seems to me that it is a bit more flickable than the 929 is. Also the shorter wheelbase helps. I haven't been able to get into some good, curvy roads yet, but i'm betting the handling is better than that of the 929. Ride quality is smooth on both bikes.
Ergos-
The S3 is probably a little better in this department, but not by much. My back and wrists are thankful for the S3's straight up riding position, although my wrists got sore towards the end of the day. The 929 also has more of a straight up riding position, which Honda is known for in their sportbike class (at least back then), but not quite as much as the S3. The seat on the 929 isn't the most comfortable and S3 isn't much better, but then again, after riding all day on any sportbike or naked bike, your tail is going to be numb. You get used to it. If you were to compare the ergos of a gixxer or yami to the S3, the S3 would take the cake in my opinion.
Wind protection-
Obviously the S3 has none. I was traveling at about 90 mph with the wind to my back and it wasn't bad at all. You get that "clean air" effect where it just flows around you with no problems. Different story if there is a strong crosswind or if the wind is coming at you from the front at an angle. It felt like I was on a bucking bronco, but then again the wind gust were 40-50 mph. On the 929 it isn't as bad because there is some protection and better aerodynamics. Buffeting or headshake isn't as bad on the S3 as it was on the 929 at higher speeds.
Looks-
My 929 was a very sharp looking bike. I had some nice aftermarket accessories on it and I always kept it in tip-top shape. Very shiny, very clean, never been down. I always recieved compliments on it wherever I went. Then there is the S3. I honestly think it is the sharpest bike i've seen to date. I love the looks of this bike. It has its own unique look that no other bike matches. People look at this bike and have no clue what it is, but they have this look of aw on their faces. Its very funny to watch. Hell, I even catch myself standing in the garage at night staring at it, my wife thinks there is something wrong with me, but it has this ability to pull you in.
Overall, the S3 is the total package--cruiser, sportbike, stuntbike, all in one. There is no way you cannot have fun on this machine. I loved the hell out my 929RR and it has way more top end than the S3, but thats about it. The 929 is a great bike, but the S3 is a better bike in my opinion and i'm looking foward to having it for a long time.
Feel free to post if any of you have had different observations with your S3. I would be interested in knowing what they might be.
warped929RR is offline   Reply With Quote
Old 04-22-2007   #2 (permalink)
This is a good comparison. I've never been on a 929, but personaly I think the roll on power of the S3 is rather weak. Maybe it's because I have an 02'. I can't ride down the highway in 6th gear @ 70mph, roll on the gas, and expect to blast off. That just isn't happening on my 02'. I could on my old 1200. It would go from 60 to 120 in a flash in top gear, but on the S3 I have to be in the right gear. If I'm in 4th @ 70 then it will blast off in a smooth manner. My 1200 was a completely different kind of bike though from the 929 or the S3. This is an interesting difference. I never would have expected it. Good write up.
Brakes are for people who ride slow.
Euro is offline   Reply With Quote
Old 04-22-2007   #3 (permalink)
I have a 01 929 right now with 25k on the clock all of it I put on the bike. I plan to but either buy a 07 or wait and see what the 08 triple has to offer. I will always keep the 929 it's just too much fun.
GPZ1170 is offline   Reply With Quote
Old 04-22-2007   #4 (permalink)
I bought a 929 new in '01 and kept it for two years. For the most part I agree with your comparison - good write-up, Warped. I found the 929 to be quicker and feel lighter in comparison to the S3, but I really enjoy the S3 a lot more than the 929 due to the torque, the riding position, and the looks. When I sold the 929 it was, in part, because I found it so uncomfortable. The seat was truly like a plank, and I didn't find the bike to feel "upright" at all. I replaced it with a 2002 Moto Guzzi LeMans, and for the first month or so - until I got used to the Guzzi - I kept asking myself "Where's the power?" when twisting the throttle. Of course I came to realize that the Guzzi was a much different bike with characteristics that couldn't be compared to the 929. I think the S3 is kind of the same - apples and oranges, so hard to compare. For me, the S3 is the bike of the moment, and I don't think I'd trade it for a different bike - certainly not for a pure sport bike like the 929 or any of the current liter bikes.
2006 Triumph Speed Triple
2007 Ducati GT 1000
1973 Moto Guzzi V7 Sport
1967 Triumph Daytona T100R
stmike is offline   Reply With Quote
Old 04-22-2007   #5 (permalink)
Funny, I like the stock seat alot. Last year a did a 880 mile day with it and my neck was sore but was about it. I do 400+ mile trips all the time with it. I cant wait until I can say I have done that on a S3.
Old 04-22-2007   #6 (permalink)
Hey, thanks guys. I wish I could've kept my 929, but I just couldn't afford two bikes. Maybe down the road i'll be able to get another one.
stmike--I may have been too vague on the ergos of the 929. I guess for a sport bike, it is more straight up than a gixxer or yamaha. I've ridden my friends' gixxers and yamaha's and my legs felt more tucked and my upper body was leaning foward more so than on the 929. I agree, the S3 has a much better riding position than any of the sportbikes. Also agree that the seat sucks on the 929.
Euro--The roll on power of the 07 S3 is good--its not blast off power of a sport bike, but still good enough and I agree, it depends on what gear your in. I feel I could ride around in 3rd or 4th gear and have enough roll on power to get up and go whenever I need it. Of course, its still not the ultra fast power surge of a sportbike, but that goes back to apples and oranges. It's a lot easier to cruise on the S3 and not having to shift all the time like the 929. At the same, I don't think the S3 was made to cruise neither, if you know what I mean. :wink:
Old 04-23-2007   #7 (permalink)
Moderator
Favorite Bike: Blue 08 Tiger -Current
ruscook's Avatar
Other Motorcycle: White07 SpdTrple -crashed
Extra Motorcycle: Red 06 Sprint -Sold
warped, nice review. The only thing I'd add which you hinted at, is the torque curve of the S3 is actually a line. It doesn't really take off and kick you in the pants because it is so linear, but also as you pointed out, comes in low and keeps on going.
I DIDN'T by a 2000 Sprint because I felt the 955 motor was lacking compared to the competition and bought a ZX9R. I have now bought 2 x 1050 motor Triumph's because the Triple in 1050 guise is a gem of a motor...... :-)
have fun and keep the rubber side down.
Russ
ruscook is offline   Reply With Quote
Old 04-23-2007   #8 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
Thanks for writing that up. It's revealing to see how the S3 fits in the wide world of bikes.
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
06 - 04 comparison StoneTriple Speed Triple Forum 7 08-14-2006 06:31 PM
Comparison of New Bonnevilles bg81 Twins Talk 7 04-09-2006 05:10 PM
Interesting comparison Kilibreaux The Rocket Science Forum 6 01-18-2006 04:16 AM
Dynojet comparison keef Twins Talk 11 01-13-2006 09:41 PM
Speed Four Comparison gundog Triumph SuperSports 12 05-19-2005 01:49 PM
