Old 04-20-2007   #1 (permalink)
They have a part online for the S3... haven't seen it discussed here. No pictures or specs on it other than it fits our bikes. I'd like to order all from them if possible.
Or a place that sales the purolator filter and the Mobil1 online?
whodkne is offline   Reply With Quote
Old 04-20-2007   #2 (permalink)
Check yer pm's! :wink:
[ This message was edited by: cheapbastard on 2007-04-20 14:40 ]
cheapbastard is offline   Reply With Quote
Old 04-20-2007   #3 (permalink)
doh!
[ This message was edited by: Briank on 2007-04-20 14:43 ]
Briank is offline   Reply With Quote
Old 04-20-2007   #4 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Oil Filter Study / Comparison
Purolator Pure One PL14610 the big winner - that's what I use.
Get it at your local Pep Boys.
GSXR 1000 Front End Swap
Old 04-21-2007   #5 (permalink)
Or you can try the Mobil 4T oil that was designed and engineered to work with the Speed Triple Here at this Triumph Site.
"The fear of death is the most unjustified of all fears, for there's no risk of accident for someone who's dead."
--Albert Einstein--
KuwlTriple is offline   Reply With Quote
Old 04-21-2007   #6 (permalink)
I prefer the Pure One PL14612 because it is the same size as the Triumph filter. The PL14610 is 3/4 inch longer and hence is more vulnerable to damage. As long as you are doing normal maintenance intervals the size is not an issue, if you plug the PL14612 your engine has much bigger issues than an oil filter can solve. I have seen photos of S3's with the PL14610 all dented and scraped. If would be easy to punch a hole in one and then you are going to have big problems even if you can keep the rubber side down.
dr_gallup is offline   Reply With Quote
Old 04-21-2007   #7 (permalink)
DEcosse's Avatar
On 2007-04-21 08:51, dr_gallup wrote:
.... The PL14610 is 3/4 inch longer .....
& that's exactly why I use it - larger filter means more filtration surface therefor better filtration & better flow.
The additional 3/4" creating vulnerability is just ridiculous - even the sump nut is lower than the base of the filter, let alone the headers which are a good 2" lower still!
If you're in the position of denting your filter you have much greater problems to worry about! :-D
Old 04-21-2007   #8 (permalink)
Sadly, I can't find anyone local that carries purolator...however, local Kragen has the Mobil1 filter.
Old 04-21-2007   #9 (permalink)
Favorite Bike: '01 Speed Triple
Whodkne, do you have Advanced Auto Parts out there? they carry the Purolator brand. I use the 14612 too. I get my Red Line 15/50 fromAl Smith Automotive (Mail order)
They sell Amsoil as well.
[ This message was edited by: Speed3 on 2007-04-21 15:17 ]
Speed3 is offline   Reply With Quote
Old 04-21-2007   #10 (permalink)
PepBoys also carries this filter. I've bought many there for other bikes.
2006 Triumph Speed Triple
2007 Ducati GT 1000
1973 Moto Guzzi V7 Sport
1967 Triumph Daytona T100R
stmike is offline   Reply With Quote
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-11-2007 11:49 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Amsoil 10W40 versus Mobile 1 oil for Sprint ST pbrokaw Sprint Forum 27 04-21-2006 06:32 PM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
