Thanks for the advice, I checked the reservoir and it is bone dry, even below the min line. I called up the local triumph dealer and they said they will take a look at it ASAP.
I'll keep you posted with the outcome.
On 2007-04-21 14:20, Speed3 wrote:
It's just marking it's territory! My '01 used to do that after a good blast, even when the level was at the low mark. I replaced it with Evans waterless coolant, and it hasn't done it since.
-I have been looking for waterless coolant, where did you find a place who sells it?
On 2007-04-21 13:20, Diego wrote:
> Check your radiator cap.
Good advice. Altitude should have nothing to do with the boiling point of coolant inside a closed system, which this is so long as the radiator cap functions properly.
-True, however once the fluid is in the reservoir (past the rad. cap) it is no longer in a closed system and will boil at lower temperatures.
[ This message was edited by: RckyMntTriple on 2007-04-21 17:19 ]
