How to Wheely, revisited! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-06-2007, 09:48 PM   #1 (permalink)
Super Modrubater
Favourite Bike: Black Speed Triple 1050
welshrob's Avatar
Other Motorcycle: 09 T100 Bonneville efi
A lot of us may have already seen these videos but I`ll post them again for the newbies. The second one, although shorter, is quite interesting too. Enjoy.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/rmduaIjSDjc"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/rmduaIjSDjc" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/ovFSahIPaVQ"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/ovFSahIPaVQ" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
"An unarmed man can only flee from evil and evil is not overcome by fleeing from it."
welshrob is offline   Reply With Quote
Old 04-06-2007, 10:03 PM   #2 (permalink)
Favourite Bike: '06 S3
dfib's Avatar
Advice from Carl O. of Ononewheel.com (He uses S3's for his class!)
I'm not sure how much practice you've gotten in since posting this, but there are a couple things I'll mention. Slipping the clutch is a bad idea. You're going to wear out your clutch super fast if you're slipping it to get the front wheel up in the air. Also, becuase of clutch wear, you would need to increase the frequency of your oil changes.
Clutching the front wheel up is done by pulling the clutch in and popping it back out almost instantaneously while under light to moderate acceleration. This is more aggressive than your slipping, but it's not going to overheat and wear out your clutch plates as quick.
I'm unsure of why you want to pull it up in second gear when you're doing it in first already. Option one being you want to go faster, and option two being you want to carry it farther. IF you're looking to carry it farther, then don't do it in second. Keep going with the first gear wheelies and bring the front wheel up higher. Bringing the front of the bike higher creates more wind resistance, and puts more of your weight back allowing you to shut of the throttle slightly to keep your speed down.
If you just want to go faster, well, that's what second will give you. The technique for getting it up should be the same for all gears if you're using the clutch, just slightly more aggressive. And COVER THAT REAR BRAKE.
"And I will not be placed under a microscope worrying about my every word and joke, no matter how clearly I spell them out." - DVS
ΜΟΛΩΝ ΛΑΒΕ
dfib is offline   Reply With Quote
Old 04-06-2007, 10:46 PM   #3 (permalink)
DEcosse's Avatar
D'Ecosse How To Wheelie Guide:
Step 1:
Install Daytona motor .............
T'Rat.net BOTM November 2009
Old 04-06-2007, 11:19 PM   #4 (permalink)
dfib's Avatar
Putting a fat chick on the back helps too! :-D
ΜΟΛΩΝ ΛΑΒΕ
Old 04-06-2007, 11:29 PM   #5 (permalink)
w00ht's Avatar
Hadn't seen those, thanks Rob.
w00ht is offline   Reply With Quote
Old 04-07-2007, 02:39 PM   #6 (permalink)
What are the magic numbers? Is first gear the easiest gear to moist a minger on the power? What speed should you be travelling and at what revs before you shut down momentarily and then open it up again? Where should I position my body?
.....enquiring minds want to know. :???:
Oedipus schmedipus! At least you love your mother.
Doc007 is offline   Reply With Quote
Old 04-07-2007, 02:45 PM   #7 (permalink)
Go pic up this months issue of Bike (yes we get UK rags in Canada), gives a good step by step how to loft yourself for beginners.
Although they rated the speed triple fourth behind a SV650 and Kawi Versys as awesome one wheel machines :???: .
"You have enemies? Good. That means you have stood up for something, sometime in your life." Winston Churchill
Trumpfan is offline   Reply With Quote
Old 04-07-2007, 04:13 PM   #8 (permalink)
dfib's Avatar
They rated the SV higher than the S3? ***! SVs are well know for having oil starvation issues when wheelied!
Doc007 - To answer your question grabbing a handfull of throttle while sitting upright (and covering the rear brake) at anything higher than 3k rpms in 1st is gonna bring the tire up. There is no need to chop the throttle first. Chopping the throttle and opening it back up aggressively in second at the 5k range will have the same effect.
ΜΟΛΩΝ ΛΑΒΕ
Old 04-07-2007, 04:42 PM   #9 (permalink)
Favourite Bike: S3
Dfib, now you mention this, does the S3 keep the oilpressure up when wheelied? No riks in longer wheelies?
I only make them max 3 seconds so don't know, and no time to watch the oillight then
It's not the strongest species that survive, nor the most intelligent, but the ones most responsive to change - Charles Darwin
Buster is offline   Reply With Quote
Old 04-07-2007, 05:01 PM   #10 (permalink)
dfib's Avatar
None that I've ever heard.
I can't imagine they have problems if the "On one wheel" wheelie school uses them. And as far back as I can remember reading the posts here, no one has ever mentioned a problem.
ΜΟΛΩΝ ΛΑΒΕ
How to Wheely, by Dani Pedrosa welshrob Speed Triple Forum 12 02-01-2008 12:50 PM
29 Dreams revisited brolane Biker Hang-Out 3 03-28-2007 02:59 PM
wheely machine Buster Speed Triple Forum 13 01-16-2007 03:51 PM
Horns Revisited retrobiker Classic, Vintage & Veteran 9 11-11-2006 11:01 PM
Revisited.. Timian Tiger Chat 4 08-10-2006 10:42 AM
