Scratched Tank - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda PowersportsOntario TourismMotorcycle.com
Old 04-05-2007, 05:02 PM   #1 (permalink)
Caught the side of the tank on my 06 Triple with my kneeslider this morning leaving a bit of a scratch. Anybody know any methods of getting rid of the scratch? I know I'll probably have to put up with it seeing as it's a plastic tank, but any advice would be helpful.
P.S. Great biking weather here in Scotland at the moment (if you can believe that!)
bvivers is offline   Reply With Quote
Old 04-05-2007, 07:52 PM   #2 (permalink)
I SAID, has anybody any advice on treating this tank scratch?
Old 04-05-2007, 08:00 PM   #3 (permalink)
Try machine buffing with a light polishing compound, Or, a cleaner wax.
You can try buffing it out by hand, A simple drill buffing attachment on low speed should get it done.
Its hard to recommend without knowing how deep the scratch is, Sometimes a little wet sanding helps before buffing.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 04-05-2007, 08:04 PM   #4 (permalink)
Thanks for the advice.
Old 04-05-2007, 10:23 PM   #5 (permalink)
KAH24's Avatar
If the scratches aren't too deep, I'd try 3M scratch remover. It comes in a tube paste formulation which worked well on removing some low front fender curb scratches on my car bumper last year. After rubbing it in with a cloth, the scratches were barely noticeable after several applications. From there, I sprayed a few layers of clear coat over it and buffed it out again. The scratches are barely noticeable even up close. Then again, I'm talking about a car and the lower bumper is a part that is hard to see.
KAH24 is offline   Reply With Quote
Scratched wheel drivingon9 Speed Triple Forum 4 08-30-2007 02:54 PM
Scratched windscreen help!! ambajack Twins Technical Talk 7 07-25-2007 04:39 PM
scratched tank wookie Speed Triple Forum 7 04-19-2007 01:35 PM
Downpipes scratched at dealers? eagle Twins Talk 1 08-10-2006 11:04 AM
Fairing scratched Shavey Daytona Deliberations 0 04-27-2004 04:31 AM
