Engine Light and Flat Battery? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-05-2007, 10:13 AM   #1 (permalink)
My battery was not strong enough to start the bike this morning. I bumped it down the road and did a one hour trip. As I got nearer home the engine light came on so I limped home.
When trying to start the bike again the battery is still too low to start it. Would this be the cause of the Engine Light too? I am hoping it is.....
Admit nothing, deny everything and always makes counter accusations!
johnwilton is offline   Reply With Quote
Old 04-05-2007, 11:12 AM   #2 (permalink)
Sounds likely. I'm finding that these bikes (S3, Daytona) are SO sensitive to battery strength. Low batteries can be responsible for a whole host of issues on these bikes from simple non-starting, sudden MIL's, stalling, and seemingly unrelated fault codes popping up on the ECM. Spend a coupld of bucks and get a good battery with at least 200 cold-cranking amps. That's what I'm doing.
Ride it, break it, fix it, repeat.....
Helmet_Hair is offline   Reply With Quote
Old 04-05-2007, 12:54 PM   #3 (permalink)
Could well be John. Get it on an Optimate. 3 cold hot cold cycles will put the MIL out.
9264 is offline   Reply With Quote
Old 04-05-2007, 01:33 PM   #4 (permalink)
YES, my dealer told me I do not want to let the battery get low or go dead.
He specifically said it would cause the bike to run like ***** or not run at all.
I bought a trickle charger that came with an adaptor I can keep attached to the battery all the time and caps off when not in use. I zip tied the lead to the tube under the seat.
J_DOGG is offline   Reply With Quote
Old 04-06-2007, 09:17 AM   #5 (permalink)
Thanks guys. I bought a new battery (prior to reading this though) I replaced it like for like. Started and fired up lovely but the management light still shows? 3 cold hot cold cycles to extinguish right??? Doesn't just go out once everything is back to normal?
Old 04-06-2007, 09:29 AM   #6 (permalink)
I am really going to show how naive I am, what is the 3 cycles routine? run then switch off? then run til hot then switch off? I usually ride them but dont do more than that....
Thanks for all your help so far.
Old 04-06-2007, 10:34 AM   #7 (permalink)
As you can see with an earlier post by me; I feel your pain with that engine light. Evidently some bikes are more prone to be enlightened. As for the cycles; mine needs some time between heat-up and cool-down. As a guesstimate I would say couple hours with my bike.
Timan is offline   Reply With Quote
Old 04-06-2007, 12:11 PM   #8 (permalink)
DEcosse's Avatar
It will go out when you have completed the 3 warm-up cycles.
A warm-up cycle is defined as:
<UL>
<LI> Coolant must be raised to > 72 C
<LI> After 72 C coolant must be raised by 23 C from start temp
<LI> Controlled Power down must take place[/list]
In simple terms start it up & let temp come up, then let it cool off a bit; repeat a couple more times.
T'Rat.net BOTM November 2009
Old 04-06-2007, 02:11 PM   #9 (permalink)
Superb guys! Thanks for all of your help! I am a happy S3 owner again.... See you all on the road.
Engine light came on after dead battery. Bearnold2 Maintenance & Workshop Talk 8 08-10-2008 09:54 PM
Battery re-charged, now engine light on. PatDPT Triumph SuperSports 5 06-14-2007 10:29 PM
Replaced battery now engine light wont go out. Kegel Triumph SuperSports 1 04-23-2007 12:09 PM
dead battery now engine light on? Tony597fitter Triumph SuperSports 3 07-16-2005 06:14 AM
Battery/engine light triumphtimes Sprint Forum 3 06-14-2004 08:27 PM
