Old 09-17-2004   #1 (permalink)
whats the best chain lube to use on my speed triple?.I just used the last of my can of "chain wax" and have to buy some more lube.
now have put on 614 miles since sat. love this bike!
thanks
pete
AH-1 is offline   Reply With Quote
Old 09-17-2004   #2 (permalink)
I use BelRay SuperClean. No fling off..
Knightshade is offline   Reply With Quote
Old 09-17-2004   #3 (permalink)
TriFlow lubricant. Not a normal choice but the can states motorcycle chain lube as on of it's intended uses. Works great as far as I can tell. Not much fling-off either.
rwven is offline   Reply With Quote
Old 09-17-2004   #4 (permalink)
Just got in from lubing my chain.
I use Bel-Ray Super Clean too.
I clean the chain with the moose chain scrubber and some WD-40, clean it off with a rag, take it for a spin, then spray on the Bel-Ray.
Been using the Bel-Ray for about 4 years now and I have had no problems with it. Good stuff.
Prubert
\'01 Sprint ST
DoD #2199
Appleton, WI USA
Prubert is offline   Reply With Quote
Old 09-17-2004   #5 (permalink)
PJ-1 blue, or whatever it's called. No fling to speak of, has worked well. A lot of people I know just use WD40 only. I clean the chain first with ProtectAll and a GrungeBrush.
[ This message was edited by: CaptainFlake on 2004-09-17 20:49 ]
Lowering the average.
CaptainFlake is offline   Reply With Quote
Old 09-17-2004   #6 (permalink)
well..if we're going to get specific.
I take the bike out for a ride to warm up the chain, then put the bike up on its rear stand, put the bike in nuetral (with the engine off of course) and spray it down with some WD-40. I then take my homemade grunge brush, (two toothbrushes taped together with duct tape) and run it through a couple of times, wipe down w/a rag, spray again with WD-40, wipe down w/the rag again, clean the sprockets, then apply the Bel-Ray SuperClean. I like it alot. I've never encountered any fling off problems and I kinda like having a white chain.
Old 09-26-2004   #7 (permalink)
My triumph dealer (So Cal Triumph.) says you dont have to lube it. It has its own resevoir.
AndrewTriumph is offline   Reply With Quote
Old 09-28-2004   #8 (permalink)
Moderator
Favorite Bike: '06 Graphite 675
TripleThreat's Avatar
Extra Motorcycle: '06 675 Track Tool
Prubert,
What size Moose Chain Scrubber do you use? 520 or 530? I see that they offer these two sizes, but can't find a number in my owner's manual that matches there numbering system.
TripleThreat
[ This message was edited by: TripleThreat on 2004-09-28 13:07 ]
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 09-28-2004   #9 (permalink)
I am using the 530 scrubber.
Prubert
\'01 Sprint ST
DoD #2199
Appleton, WI USA
Old 10-07-2004   #10 (permalink)
I use Profi Dry Lube. Good stuff, doesn't attract grit like some of the 'stickier' lubes.
My understanding is that WD40 shouldn't be used to clean the change as it can have a detremental effect on the rubber 'O' rings. Diesel or paraffin (Kerosine) is usually recommended.
Chain Lube... Blacklion50 Modifications & Workshop Talk 4 05-03-2007 04:17 PM
Chain lube? MickMaguire Modifications & Workshop Talk 41 03-25-2007 01:30 PM
Chain lube rays323929 Twins Talk 3 05-05-2006 09:07 PM
To Lube the chain or not to Lube...that is the Question Clanrickarde Twins Talk 27 02-25-2006 08:37 AM
Chain Wax vs. Chain Lube Celeste Twins Talk 4 09-01-2005 12:14 AM
