Progressive Insurance
britishcustomsBikeBanditTriumphPerformanceUSAAmericanMotorcyclistAssociationMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmoryMotorcycle.comCycleGear.combritishcustomsSportbikeTrackGear
Old 04-02-2007   #1 (permalink)
Hey Guys....I haven't been on the forum in awhile....been SO busy at work. Hope all of you are well. :-D
I am posting a two-part question here for a buddy that recently bought a Speed Triple and he needs some feedback.
Issue 1: He is experiencing dripping oil that has stained the portion of exhaust directly under the right foot peg. He can't find any leaking seals and the dealer seems to think the draining is from the "breather tube" ???
Issue 2: He recently purchased a pair of bar risers which require a longer clutch and brake cable. Where can he find these?
Any help you guys can give would be greatly appreciated.
Thanks!
JOHN
North San Diego
RAT Leader
graciejohn2 is offline   Reply With Quote
Old 04-02-2007   #2 (permalink)
Favorite Bike: Custom Daytona
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Extra Motorcycle: SV650S
On 2007-04-02 20:01, graciejohn2 wrote:
Issue 1: He is experiencing dripping oil that has stained the portion of exhaust directly under the right foot peg. ...
Under the right peg I'd be more inclined to think brake fluid!
GSXR 1000 Front End Swap
Suzuki TL1000S................Suzuki SV650S.............Triumph Daytona
http://www.triumphrat.net/image.php?type=sigpic&userid=2434&dateline=1225242  733
Old 04-02-2007   #3 (permalink)
Welcome! Being a n00b myself I researched the same brake line issue. I found that the folks at CycleBrakes (http://www.cyclebrakes.com/) we're very helpful. They suggested a dual line setup for safety (he didn't like the thought of the brakes relying on the single caliper point of failure). On my call he said simply use their meauring guide to know what angle of ends to get and measure the distance with coax cable (give the same density as brake line) and they will have Galfer make the lines for you and send them out in a day or two.
whodkne is offline   Reply With Quote
Old 04-03-2007   #4 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
You sure it's not a leaky filler cap seal? Nice to see ya again John! :-D
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
Extended Cables for 04 America Kremen Twins Technical Talk 4 10-25-2007 07:11 AM
Clutch Lifter Arm oil leak TheWOLF Modifications & Workshop Talk 0 09-13-2007 05:03 PM
extended cables? 666Bonneville Classic, Vintage & Veteran 0 06-12-2007 12:53 AM
small oil leak from clutch on engine Crogers Speed Triple Forum 2 05-11-2007 09:58 PM
Clutch cover oil leak TJSpeedmaster Triumph SuperSports 1 07-21-2004 11:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
