AdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Trident-Exhausts.com
Old 03-28-2007   #1 (permalink)
HiVel's Avatar
I Finally got a 44 tooth sprocket-I had ordered three of these things and finally somebody sent me one. It is black, hardened aluminum and is drilled out real cool.
It took about 20 min to put it on cuz I was doing some cleaning (OC) around the rear wheel. I have a 17 on the front! Tomorrow I hope i will test as I am a bit under the weather right now-hope I can keep the front end on the tarmac. I will prob take the17 off and go back to 18 stock thinking that is a sharp turn for the chain and the bigger one wil afford better wear and less stress on all systems involved.
Will let yall know ASAP how it does for me.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 03-29-2007   #2 (permalink)
I've got 17/45 on mine and it turns the bike into a real screamer. Instant-on power in any gear and it goes like crazy straight to redline. The only downside is that your revs will be a bit higher and you won't be able to go much faster than 130mph (actual). As long as you don't go much smaller than 17 on the front, the chain shouldn't be too bad off.
Old 03-29-2007   #3 (permalink)
still happy with my 17/44 , but I don't have as big a motor either.
rckrzy1 is offline   Reply With Quote
Old 03-29-2007   #4 (permalink)
HiVel's Avatar
Thx-good info-did not get to ride today as I have allergy to max pollen count for the year today!! Maybe it will rain soon and I will get some clean air so i can breathe OK
Old 03-30-2007   #5 (permalink)
I left the front stock and went to a 45 rear and love it! this is how they should of done it from the factory!!!!! when I did it I went to the 520 chain conversion as well....
[ This message was edited by: hool-a-gan on 2007-03-30 11:52 ]
2005 Speed Triple, BMC air filter, Blue Flame EVO's, Power Commander, Matris M4R,Skyking sliders,Sargent seat,WoodCraft clip ons,
http://i72.photobucket.com/albums/i1...IMG_1267-1.jpg
hool-a-gan is offline   Reply With Quote
Old 03-30-2007   #6 (permalink)
HiVel's Avatar
Gotta say it really perks the Speedy up!! Do a TON in a couple of heartbeats! (and a few shifts) Now I am really in trouble -the response is almost too quick-gotta get adjusted to a new quickness level!! FUN bike.
Old 03-31-2007   #7 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
Hivel,
Did you recalibrate your speedo? There is probably a 20-25mph error with your current configuration, correct.
Nevertheless it must be even harder keeping that front wheel down on the ground. :-D :-D :-D
I think I will go to the 44 tooth this season.
Thanks for all the input.
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 03-31-2007   #8 (permalink)
How do you calibrate the speedo? Mine is off by about 5 mph.
tomstumble is offline   Reply With Quote
41 tooth rear sprocket for Thruxton ??? robnobrakes Twins Technical Talk 5 01-18-2007 10:08 AM
Can't find Renthal 44 tooth rear -Help HiVel Speed Triple Forum 4 08-26-2006 06:12 AM
99-04 Rear Hugger Install Tip TXRyder Sprint Forum 5 04-14-2006 10:48 AM
Difficult rear tire install Ugarte The Rocket Science Forum 12 11-15-2005 02:31 PM
15 tooth 47 tooth sproket set up? TJSpeedmaster Triumph SuperSports 3 04-07-2005 10:39 AM
