Old 03-26-2007   #1 (permalink)
What does the 12000 mile service entail, and how much should i expect to pay for it? My 02 Speed 3 is at 12.5k and I am wondering if i should do it myself or have it done. It runs like a top i am inclined to say "screw it" until later in the summer but dont want to hurt it any.
PROMOD1385 is offline   Reply With Quote
Old 03-26-2007   #2 (permalink)
Diego's Avatar
The 12,000 mile service is a big one. It includes the valve check and possible adjustment thereof.
Even if you decide to risk the valves being/remaining in tolerance for the duration of the summer, at least do the oil and filter change now!
John
Diego is online now   Reply With Quote
Old 03-26-2007   #3 (permalink)
There are a couple of threads that post the checklist for the service intervals for several of the Speed Triple models. Probably the most important check is the valve clearance, but other important checks, such as wheel bearing repacking and coolant flush need to be done.
Most of these things can be done by someone who is mechanically inclined.
Enjoying the naked life.
BillT is offline   Reply With Quote
Old 03-26-2007   #4 (permalink)
Chris3D
Checking the valve clearance is pretty easy, I just did it for the first time on my Busa @ 28,000 miles and only two valves were near the tight end of tolerance. Adjusting the valves isn't even that hard if you're not afraid of pulling the cams out. If the thought of doing that scares you, it'd probably best be left to a shop, otherwise anyone with a basic set of tools can do it themselves.
Old 03-26-2007   #5 (permalink)
Right this is a big one. All my valves were out and it runs so much better now that they have been set right. Also wheel bearings packed, most poeple forget this one. If you check this service list it's most of them that are done on 12,000.
Check list - Speed Triple
xSpeed3x is offline   Reply With Quote
Old 03-27-2007   #6 (permalink)
HARVEE's Avatar
if you can do some your self like changing coolant brake fluids/pads the easy stuff will cut labour time a bit.
HARVEE is offline   Reply With Quote
Old 03-27-2007   #7 (permalink)
What should i expect to pay/ how many shop hours for the valve adjustment?
Old 03-27-2007   #8 (permalink)
I would add repacking the rear suspension linkage.
Mine needed it.
PhilM is offline   Reply With Quote
Old 03-27-2007   #9 (permalink)
HARVEE's Avatar
i paid £300. .....$580
but i done the coolant,brake pads/ fluid.air filter..
Old 03-27-2007   #10 (permalink)
I paid $470 for mine...everything was in spec.
Always get an estimate up front, it should always be your practice when taking bike in for service.
jasonworthing is offline   Reply With Quote
12000 mile Service - What you pay? xSpeed3x Speed Triple Forum 24 07-10-2008 11:41 PM
12000 mile service hinkleyboy Triumph SuperSports 15 06-24-2006 01:40 PM
12000 mile service Mullethead Daytona Deliberations 6 05-05-2006 09:09 AM
12000 MILE SERVICE ColinHitchcock Triumph SuperSports 5 03-22-2006 05:41 PM
12000 mile service CATUCK Tiger Chat 7 12-20-2005 05:41 AM
