As far as my knowledge of physics go:
Backpressure itself will not help BUT if reflection of pressure wave comes back to exhoustvalve whith low pressure when it opens up, gas will be released easier, this will result in better torque. So in theory the best is to have no backpressure but make advantage of high/low pressurewaves.. That is why some bikes have a connection between headers from different cylinders...
As for the intake it's the other way around, an airbox, turbo or other charger will generate more pressure, so when inletvalve opens, more air in cylinder.
I might be wrong though :-D
It's not the strongest species that survive, nor the most intelligent, but the ones most responsive to change - Charles Darwin
