Old 03-16-2007   #1 (permalink)
I wish I had the luck most of you guys have when checking valves. I found all Ex valves at the limit .15mm so I'm not leaving them there , I will re shim for .20 and hope at 24K they are still OK.
And 4 In valves at .06 and 2 at near 0 , luckily the 2.70 shims in the Ex will take care of the 4 In valves .
But I still end up needing 8 2.65mm shims @ $7 a pop. I guess I am lucky that we have 2 triumph shops in the area as One has 7 the other has 3 of them.
rckrzy1 is offline   Reply With Quote
Old 03-16-2007   #2 (permalink)
I don't know about the 97s, but the shims, I think are the same 25m on the T300s. These are pretty common. You could probably get cheaper at a Japanesse make dealer or even used shims- just mic them.
Zip
"You don't know what you don't know."
zippythehog is offline   Reply With Quote
Old 03-16-2007   #3 (permalink)
Thanks,
I needed to know those that.
Say it Loud, "I'm Black and I'm Proud"
http://i134.photobucket.com/albums/q...IMG_0625-1.jpg
Boezack is offline   Reply With Quote
Old 03-16-2007   #4 (permalink)
Wow, isn't the EX spec .30 to .20? and intake .10-.20 ? I forgot already, My Ex were all at .30, since they tend to tighten, I just left em there.
I paid $8 for my two shims. Now I gotta adjust the headstock bearing and lube the rear wheel bearing.
Triple_Rider is offline   Reply With Quote
Old 03-16-2007   #5 (permalink)
Pretty sure Yamaha shims work, and they're half the cost.
Ride it, break it, fix it, repeat.....
Helmet_Hair is offline   Reply With Quote
Old 03-18-2007   #6 (permalink)
On the 97 885 it;s .20-.15 EX and .15-.10 In .
Valve clearance? Mp350 Twins Technical Talk 12 08-19-2007 07:08 PM
12k Valve Clearance: All valves off? Icarus Triumph SuperSports 2 07-28-2007 12:58 AM
Valve clearance stuff... MotT3 T3 Sport / Touring Forum 9 05-12-2007 05:28 AM
Valve clearance specs? boredinocala Sprint Forum 5 07-27-2006 05:28 PM
Valve Clearance Findings ohiorider Twins Talk 12 04-27-2006 07:16 PM
