Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 03-16-2007   #1 (permalink)
I noticed today that there is some play in my rotors, between the actual rotor and the gold part that mounts to the wheel. About 2-3mm. Is this normal?
Triple_Rider is offline   Reply With Quote
Old 03-16-2007   #2 (permalink)
yes
portisroads is offline   Reply With Quote
Old 03-16-2007   #3 (permalink)
Lom
Yes, the sideways movement is for optimal pad/disc surface contact, and the rotational one, from what I was told, is to accomodate the rotor's expansion under heat.
I'M IMMORTAL
well...so far.
http://www.triumphrat.net/albums/alb.../aad.thumb.jpg
Lom is offline   Reply With Quote
Old 03-16-2007   #4 (permalink)
Makes sense, thanks
Old 03-16-2007   #5 (permalink)
Hence the term "floating rotors". :-D
kcjones is offline   Reply With Quote
Old 03-16-2007   #6 (permalink)
I didn't really worry till I compared them to the rotors of a ZRX and R6, which were both pretty firm. I was all ready to buy some wave rotors.
Old 03-16-2007   #7 (permalink)
If you need the excuse, er.. uh.. they're supposed to be tight.. yeah, really tight.. no movement at all. You need new rotors. :wink:
There is no theory of evolution, just a list of creatures Chuck Norris allows to live.
EODjeff is offline   Reply With Quote
Old 03-16-2007   #8 (permalink)
alright, lemme practilce... Uh honey... there's a problem with my bike.....
Old 03-17-2007   #9 (permalink)
Triple rider, you think yours are loose? wait til you get full floaters. When i got mine, they made so much noise I kept checking them to see if they were coming off. Now when I go over a bump at slow speed, I hear them and think nothing of it. But, I would double check yours, it sounds like they might be broken........
Go Hard or Go Home!!!!
satansk9 is offline   Reply With Quote
Are you up with the play ? Tbirdnz Biker Hang-Out 10 09-21-2007 07:30 AM
Can I Play Too? nexus_7 Twins Technical Talk 3 03-09-2007 08:29 PM
Play with the HOF doodledog Biker Hang-Out 10 02-21-2007 09:48 PM
new toys to play with!!! JackSparrow Speed Triple Forum 0 08-10-2006 01:40 AM
I just got a new s4 can I play now doodledog Triumph SuperSports 10 03-28-2006 10:13 AM
