BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
ShopTriumph.com
Old 03-14-2007   #1 (permalink)
StealthS3
Just took my bike into the dealer and they suspect I have a bad font wheel bearing. I have a 2006 S3 and noticed a noise coming from the front end after 400 miles. It starts at 34mph gets load at 36 mph and stops at 37. This also happens at 71mph. I thought it might be a wheel balance problem but the dealer was concerned with the noise. Has anyone else experienced this? Not to worried other than the fact the dealer says nothing is under warranty until approved by Triumph :???:
Old 03-14-2007   #2 (permalink)
see my reply under the common issues thread
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 03-14-2007   #3 (permalink)
Favorite Bike: 2002 Speed Triple
Other Motorcycle: ATK250LQ
I just changed my front wheel bearings which were definitely bad. They caused a very noticable vibration in the bike at low speeds (25 MPH or less). Didn't notice it at higher speeds at all.
xpwarrior is offline   Reply With Quote
Old 03-15-2007   #4 (permalink)
do you notice the vibration through the footpegs or the steering wheel? In my bike i feel a vibration from the footpegs at around 50-55Km/h and i cant find the source. Is the same with you?
soze is offline   Reply With Quote
Old 03-15-2007   #5 (permalink)
On mine I felt it through the bars. With the front end off the ground I could hold onto one of the forks and spin the wheel and really feel it that way to.
Old 03-15-2007   #6 (permalink)
Favorite Bike: 06 Triumph S3
eyeque's Avatar
Other Motorcycle: 06 Daytona 675
Extra Motorcycle: 01 Aprilia RSV Mille
Doesn't the bike have a 2 year warranty?
eyeque is offline   Reply With Quote
Old 03-15-2007   #7 (permalink)
If it is just a clicking and not a wobble or vibration, it could just be a clicking spring clip on your front rotors.
Front wheel bearing numbers ? BorgCymru Twins Technical Talk 0 07-23-2007 02:42 PM
Front wheel bearing size for 03 Speed 3 Klugman Modifications & Workshop Talk 3 10-09-2006 12:04 AM
Wheel Bearing ID's guydan Tiger Workshop 2 03-04-2006 10:53 AM
Found Grease Around Front Wheel Bearing... MiamiDave The Rocket Science Forum 6 07-26-2005 02:52 PM
Front wheel bearing replacement Apidae Triumph SuperSports 6 05-04-2005 12:49 PM
