BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
ShopTriumph.com
Old 09-03-2004   #1 (permalink)
I did my first oil and filter change last weekend, had 530 miles. Used the triumph Mobile 1 (4t ?, if I remember) oil. My gear changes were getting very notchy and clunky before the oil change. Now it is better, but still have a very noticeable clunk going into 1st, and slightly notchy through the gears. Before the change I actually found a neutral between 5th and 6th. Is that possible? I swear I was cruising, barely tapped it up into 6th, and there was neutral. I thought I did some thing wrong (brain fart with the clutch in and gassed it), but later that day did the same thing. It happened 3 times before the oil change. Hasn't happened since the oil change though.
Also, when I got the bike it seemed to have too much oil, I let it go thinking I was just going to have to figure the dip stick and bike position for correct reading. The bike did use oil on the run-in, but still read good all the way to 500 miles. When I drained the oil, it was right at 4qt. The manual states 3.2qt with filter change. When I changed it, added oil, I put in 3 full qt, checked it after running it for a few minutes. It needed the extra .2, so I added apx .2-.25. That gave me the perfect reading on the dip stick, with the bike level.
Maybe thus had something to do with the clunky & notchy feel.
Bottom line, the oil is right on now, but still have a clunky and notchy shift, but is some what better than before.
Any word, any like probs? If I'm hitting stuff from the FAQs, please refer me to links. Thanks all.
M2MG is offline   Reply With Quote
Old 09-03-2004   #2 (permalink)
Don't worry just yet, trannies take some time to break in.
Picked my S3 up with 3.3k on it, and the shifting was a bit notchy yet. Just changed the oil out and put in Shelll Rotella T Synth and it is shifting much better at 6K.
When I got my '97 VFR it has 2K miles on it and the transmission was horriable. It would not go into gear, had false neutrals all over, and was very notchy. I was using regualar honda Dino oil and it would shift like total crap when the oil had about 2K on it. As I rode it, it got better. When I switched to Rotella T Synth, it got great. The last 20k (traded the bike in with 49K on it) the transmission shifted like it was a hot knife thru butter.
Bottom line, use the synthetic oil and let the bike break-in.
Later.
[ This message was edited by: Prubert on 2004-09-03 09:36 ]
Prubert
\'01 Sprint ST
DoD #2199
Appleton, WI USA
Prubert is offline   Reply With Quote
Old 09-03-2004   #3 (permalink)
I think Triumphs just a take a while to break in period. My brother's TT was, asccording to him, like a new bike after about ten thousand miles or so. I'd just be patient, keep up with routine maintenance, and ride the crap out of the thing.
Lowering the average.
CaptainFlake is offline   Reply With Quote
Old 09-03-2004   #4 (permalink)
I have just a bit over 6000 miles on the bike and the gear change to first gear is still clunky but as the other riders posted it's finally starting to smooth out. I was also able to get a neautral from 5th to 6th with the stock gearing and since I dropped the front tooth down I have yet to experience this plus with the added mileage that may be a factor after all.
cheers,
Scott
nyspeedtriple is offline   Reply With Quote
Gear Change (RPM) eternity Twins Technical Talk 8 01-16-2008 12:42 AM
Just taken delivery! Gear change and oil fill question. jonboy99 Street Triple Forum 8 12-26-2007 12:20 PM
Gear Change and New Boots smegin Sprint Forum 4 01-25-2007 08:39 PM
Gear change rubber Edsfour Triumph SuperSports 4 01-19-2007 08:17 PM
gear change mrcheese Modifications & Workshop Talk 0 03-21-2006 04:11 PM
