Motorcycle.com
Old 09-02-2004   #1 (permalink)
My 02 started dribbling from the head gasket at the RHS front (where there is a bit of gasket showing through)
Anyone had any experience of how many labour hours are required to get to it (the manual says the engine has to come out)?? Has anyone ever attempted to take out the engine themselves? All sounds expensive!!
shards is offline   Reply With Quote
Old 09-07-2004   #2 (permalink)
Favorite Bike: tied between my '02 S3 and my '06 R3
Other Motorcycle: Bonneville
Yep Mine too!
Its in the shop right now GGGRRRRRR!!!!!!
Just called the shop and they don't know why they are going to open her up and get back to me!
mine started after i hit the 130mph mark on mine checked it out in the am before the ride and it wasn't there then when we got to our rest stop it was.
I think its just from a pressure build up in the crank case. And the leak is more of an ooze than a leak
I know its not much help but I feel your pain
That which doesn't Kill you will only require brief Hospitalization!!!!
felixEOD is offline   Reply With Quote
Old 09-07-2004   #3 (permalink)
Yes, now that you mentioned your 130, I realised that just before I got home and found the dribble (you're right, it's not really a "leak") I has revved out to almost red-line. Does that mean that even if we fix our bikes, they are always going to "blow" under pressure??
Old 09-10-2004   #4 (permalink)
Maybe so!
But i'm stil gonna have it checked and if theres a prob with the head i'm going to swap it for a daytona head and get the extra 28bhp!
Old 09-11-2004   #5 (permalink)
Just curious - whereabouts on the head did yours leak. Mine started on RHS front corner (just where the extra bit of gasket sticks out!).
Old 09-12-2004   #6 (permalink)
mines leaking in the same spot.
i think that bit of filter might be acting like the wick in a kerosene lamp and pulling it out too.
HELP! oil leak from osf corner of head gasket,only 1300 miles on the clock slade Twins Technical Talk 1 05-08-2007 05:47 PM
HELP! oil leak from osf corner of head gasket,only 1300 miles on the clock slade Twins Technical Talk 7 05-08-2007 04:24 PM
05 speed 3 head gasket leak jnicosia Speed Triple Forum 6 11-25-2005 07:00 PM
Oil Leak head gasket? and looking at Dennis's T100 at dealer jwpT100 Twins Talk 3 11-17-2005 08:39 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
