Rule number 1:
If it doesn't require more fuel, it doesn't flow more air, and it doesn't make more power.
That being said, it can make a couple hp more and simply lean out the fuel curve a bit.
Almost any silencer for your bike CAN be run without tuning. The problem is that the stock tuning is already lean in the midrange.
Almost all aftermarket silencers will make close to the same power just by bolting them on. This is good for the look and sound many want.
At a later date you can add tuning and get performance gains. Or not. It is up to you.
Reinstated
