+1 to pretty much everything said here.
I had the same problem just a month or two ago. My bike was having kind of a hard time starting when it was cold ( a lot of cranking) and then the speedo wouldn't register. I would turn it all the off and re-start it, and everything would work fine. My battery finally died, and when I replaced it the problem went away and it starts really easy when cold now. However, my "check engine" light came on after I changed the battery. Some of the guys here said it takes three run cycle to operating temp and cooling down before the ECU will cancel the light after the battery is changed, because a low voltage was sensed. I've only riden it twice since then so I can't back this up, because it's winter. I have however let it idle in the garage up to operating temp a few times, and the light is still on so I'm not sure if those don't count or what. My bike runs great, but the light is on.
Brakes are for people who ride slow.
