Brembo Question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-08-2007, 01:23 PM   #1 (permalink)
I could not find THE definitive answer to this question, even after reading 75 or so posts. Here is the question:
I want to replace the master cylinder and front breaks with Brembo products. Are there "bolt on" replacements that require no fabrication? If so, what are the part numbers I need to order and what are some sources for the parts?
Thanks in advance....
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Old 02-08-2007, 01:56 PM   #2 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Definitely not THE definite answer, but I looked into this last summer and the problem is that most Brembo calipers are not with the 108mm Japanese bolt spacing that Triumph uses, but the Italo/Euro one.
The lowest spec 108mm Brembo calipers I could find were 700+ euros A PIECE. This is pretty much where I decided to can the whole idea.
Caliper x 2 + Mastercyl + lines + misc spacers and supplies
= 1400 + 250 + 100 + 50
= 1800 eur minimum
= too freaking much for brakes.
Discacciati does cheaper replacement calipers in correct spacing, but I have never used them so cannot say anything about quality.
Edit. Oh, forgot to answer your question: yes, there are direct bolt on replacements. You just need a deep wallet, calipers with correct bolt spacing and suitable caliper spacers. Any Brembo shop should be able to sell you the spacers too. www.carpimoto.com is one if you want to order online.
Edit. Disclaimer: as I have not done the actual replacement, don't come crying back if something with the above specs does not fit after you have bought the stuff...
:-D
[ This message was edited by: Martin_R on 2007-02-08 12:02 ]
Martin_R is online now   Reply With Quote
Old 02-08-2007, 03:59 PM   #3 (permalink)
bkrbil's Avatar
1800 euros = $2,343.60.
2007 Triumph Rocket III, 2006 Triumph Speed Triple, 2004 Honda NRX1800 Rune, 2002 Honda GL1800 Gold Wing, 1998 Honda GL1500CT Valkyrie & 1988 Honda CBR1000 Hurricane
and my wife's
2005 Honda VTX1300R & 2004 Honda VT750CA Aero
bkrbil is offline   Reply With Quote
Old 02-08-2007, 05:01 PM   #4 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
You could do a complete GSXR front end swap AND have the legs reworked by Thermosman for that price.
Old 02-08-2007, 05:10 PM   #5 (permalink)
I've been scoping out ebay and there's a guy selling a pair for $500, which is an amount I would consider. However, even though he says they'll fit Japanese makes, he doesn't say what the bolt pattern is.
gr8shandini is offline   Reply With Quote
Old 02-08-2007, 05:19 PM   #6 (permalink)
Hummmmm....OK, what about just a bolt-on option for a larger piston master cylinder?
Old 02-08-2007, 05:20 PM   #7 (permalink)
i just have the brembo MC not the brakes.
the MC on my bike is: #4759
zooplancton is offline   Reply With Quote
Old 02-08-2007, 05:23 PM   #8 (permalink)
Did it make a difference and where did you get it?
Old 02-08-2007, 09:49 PM   #9 (permalink)
well, that's kind of hard to answer if it made a difference because i never got to feel the stock brakes working properly. it feels great though (now).
lots of "feel" to the brake.
i bought mine from my dealer in SF.
Old 03-20-2007, 12:58 AM   #10 (permalink)
= 1800 eur minimum
Sorry to bring the thread back from the dead, however I thought you guys might want to know the new 1098 comes stock with 108mm brembo monoblocks. I have no clue wether the width of the rotors would be at all compatable. Also according to all reviews theyre incredible brakes and I plan on picking up a set as soon as I find some, along with a bilet gp master of corse!
[ This message was edited by: bcade on 2007-03-19 23:09 ]
bcade is offline   Reply With Quote
wHO HAS USED A BREMBO mc TO FIX BRAKES golden-calf Speed Triple Forum 8 09-27-2007 09:48 AM
brembo master cylinder scoobydoo Sprint Forum 0 05-21-2007 11:59 AM
brembo / pazzo lever install: zooplancton Speed Triple Forum 7 02-12-2007 04:23 PM
Pazzo lever on Brembo 19x20 moyster Speed Triple Forum 2 01-26-2007 08:41 PM
Brembo Brake Replacement riceburner Speed Triple Forum 2 06-28-2006 04:18 PM
