What damage could be done?? Advice needed - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports New Bonneville
Old 02-08-2007, 07:46 AM   #1 (permalink)
2,000 kilometers ago, I took my bike in to a Triumph dealer for a front tyre fitting. I left it on the bike as I don't have a front stand. Today it's been into a different dealer for the brake fix. When I went to collect it, the service manager said "hey, why have you got your front tyre fitted backwards?" Closer inspection revealed that the ENTIRE WHEEL assembly was installed backwards . Now, will anything be damaged? Obviously the discs have rotated backwards and onto the wrong pads which can't be good? What about wheel bearings, will they be OK?
I was with Welsh Rob when it was discovered and was ready to go straight to the dealer and punch the service guy in the head. I have calmed down a bit now but would value your opinions as to what would you do? Luckily living where I live I've not ridden in the wet, the gut reckons I'd have probably have gone down if I had Don't want to do that with $3,000 worth of paint :evil:
1050Pome is offline   Reply With Quote
Old 02-08-2007, 07:54 AM   #2 (permalink)
Doesn't everything rotate in the opposite direction in OZ. :-D I don't think it would do any damage. but what do I know? :hammer:
Sarcasm. Is just one more free service I offer.
Limey is offline   Reply With Quote
Old 02-08-2007, 07:57 AM   #3 (permalink)
Super Modrubater
Favourite Bike: Black Speed Triple 1050
welshrob's Avatar
Other Motorcycle: 09 T100 Bonneville efi
Yes, I was with 1050POME when we discovered it. He`s one VERY big bloke who was VERY pissed off with his local dealer. Luckily, he went home to calm down instead of going straight to the shop or it would have been "nosebleed city!" The S3 front wheel can be put on either way, the most obvious problem is that the front tyre is running backwards. Other implications are that the discs may warp as a result of changing sides. This could have been quite dangerous in the wet. Not funny.
"An unarmed man can only flee from evil and evil is not overcome by fleeing from it."
welshrob is offline   Reply With Quote
Old 02-08-2007, 07:58 AM   #4 (permalink)
:-D direction is the same, we're just the wrong way up. It's good apart from the blood rushing to your head. My blood will be up tomorrow when I go see the dealer :evil:
Old 02-08-2007, 08:00 AM   #5 (permalink)
Favourite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
It most likely handled a little poorly. The dealer is supposed to check tire rotation direction before mounting. WOW! He must be a real Dumb Ass!!!
Ton Up!
TonUp is offline   Reply With Quote
Old 02-08-2007, 08:02 AM   #6 (permalink)
Stuff the paint mate. You've got more than 3 grands worth of skin!
I don't think you should have any problem with the bearings and brake rotors. The bearings are usually ambidexterous.
The tyre is usually rated one direction for high speed/forces.
We used to run Pirelli silver dots backwards on the front as they got more stress from braking.[they only rated them for one end I think]
I'd hit them up for a new front tyre 'cause you can't trust it now.
Then kick his aass.
Was the origional dealer Brisbane based? PM me if you prefer.
AA
amberale is offline   Reply With Quote
Old 02-08-2007, 08:02 AM   #7 (permalink)
The bearings don't care what direction they rotate. But the tire tread IS directional for water displacement. I doubt seriously that there is any damage. Just bed in the pads again when it is fixed.
Shoot a photo of the tire and send it to Triumph with a brief letter about the quality of this dealers service. Then contact OWNER of the dealership that mounted the tire. Let them know you have serious doubts about their abilities and that you have contacted Triumph about this. Have them refund the cost of the service work on the tires and fix the problem. Make sure they have a "talk" with the service manager.
Service quality everywhere is falling apart. If you don't take this seriously, neither will the dealer and service manager.
[ This message was edited by: Devious2XS on 2007-02-08 06:04 ]
Reinstated
Devious2XS is offline   Reply With Quote
Old 02-08-2007, 08:24 AM   #8 (permalink)
Tonup, strangely enough it handled fine..... In the dry.
AA, they are Sunshine Coast based. Nice little sig btw :-D
Devi, already got the pictures but was thinking of using it as a bargaining tool with the dealer before sending to Triumph, see what they offer first... I have e-mail address for top guy in Oz and also customer service manager in the UK. If I don't get a satisfactory response tomorrow, I'm gonna make them real uncomfortable...
Old 02-08-2007, 08:30 AM   #9 (permalink)
Good plan. Get what you can. :wink:
Reinstated
Old 02-08-2007, 08:34 AM   #10 (permalink)
Favourite Bike: 2006 Speed Triple (black)
Not cool. Fukkin idiot! You put your trust in these guys because you think they are experts but some of them really don't know what they are doing. I would be PISSED.
OT: Limey, your one liners crack me up!
KarmaPunk1 is offline   Reply With Quote
advice needed bricktop Twins Technical Talk 11 08-09-2007 07:17 PM
Advice needed oldmanjob The Rocket Science Forum 8 06-09-2007 11:06 AM
Help !!!!! Advice needed.. tccox Twins Technical Talk 15 05-11-2007 05:48 PM
Advice needed rkx Sprint Forum 17 06-07-2005 10:30 AM
Help- advice needed! RandyDTFR Triumph SuperSports 17 09-05-2002 08:56 AM
