AdvanstarMotorcycleShows
Old 02-02-2007   #1 (permalink)
I am putting on a set of RC bend Fat bars and TAG risers, They are a little taller, For my 5'6" frame, I want to sit a little more upright like my Supermoto.
I know I'll need longer brake lines, I'm puttin on dual lines and don't want to tear everything apart until I have all the parts ready.
I'd like to have a double banjo with a bleeder valve for the MC and bleeder banjos for the calipers.
Anyone know what size and/or thread pitch I will need for ordering the banjos?
Also a good source for ordering the lines would be handy.
Thanx.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 02-02-2007   #2 (permalink)
I have a very large banjo, thank you, but that's a wierd question....
05 Speed Triple
jdub3 is offline   Reply With Quote
Old 02-02-2007   #3 (permalink)
Banjos are sized for the bolts they fit, in this case 10mm.
Get crush washers as well.
For brake lines, do a search for "goodridge brake lines".
Reinstated
Devious2XS is offline   Reply With Quote
Old 02-02-2007   #4 (permalink)
Just to add to Dev's............10mm and 1.25 thread.
I've got Hel, no complaints.
Avi8or is offline   Reply With Quote
Old 02-03-2007   #5 (permalink)
kwajazz is offline   Reply With Quote
Old 02-04-2007   #6 (permalink)
Again guys Fastenal sells all sizes of Banjos. Just ask!
ANY COLOR AS LONG AS IT IS BLACK!
YELLOW IS OK AFTER A FEW PINTS!
AND LOOK! THERE GOES A CHICKEN!
ORCA is offline   Reply With Quote
Old 02-04-2007   #7 (permalink)
Hairball
I think you will find what you are looking for at...
Spiegler
I fitted them to my calipers to bleed them effectively.
you can see the pictures at the bottom of this page..
Pic]Pictures
Lowgloss is offline   Reply With Quote
Old 02-04-2007   #8 (permalink)
Thanx for the connection Lowgloss.
Exactly what I'm looking for, Do you happen to have the part number?
I will be going longer to double lines in front, so everything may be different depending on the brake line banjo thickness.
Nice job on the bike!
Are those the 1 1/8 TAG bar risers?
Any trouble fitting them?
Banjo bolt specs. Eric3742 Twins Technical Talk 1 09-24-2007 11:33 AM
Brake Banjo Sizes ? timritaharry Modifications & Workshop Talk 2 04-20-2007 11:50 AM
Banjo Bolt Size? kuhlka Speed Triple Forum 1 11-01-2005 10:47 PM
banjo bolts oldyeller Daytona Deliberations 7 04-24-2005 11:57 PM
banjo bolts on 04 Daytona oldyeller Modifications & Workshop Talk 5 04-24-2005 08:21 PM
