Motorcycle.comAdvanstarMotorcycleShowsBikeBandit
Trident-Exhausts.com
Old 02-01-2007   #1 (permalink)
Hi guys,got some short levers in blue today,are there any snags in fitting them(no yellow or black ones stop quicker) jokes please.
Spendthrift is offline   Reply With Quote
Old 02-01-2007   #2 (permalink)
RTFM!
Read the ...instructions! And make sure you use the required insert/bushing from the stock levers.
Reinstated
Devious2XS is offline   Reply With Quote
Old 02-01-2007   #3 (permalink)
If RTFM means what i thought,are you having a bad day?
Old 02-01-2007   #4 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
There is one hitch I had (mainly on accounta I didn't RTFM :-D )
While you may be able to get enough slack in the clutch cable with the adjustment wheel at the lever, it's a whole lot easier if you just loosen it down by the engine (just make a note of where the adjustment/lock nuts are there - no big deal).
I've got 'em on the S3 and TT. Kinda wish I had shorties on the Triple.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 02-01-2007   #5 (permalink)
As Devi said you'd need the brass (I think) bushing from the original clutch lever. Otherwise it's fairly straight forward.
I'd take the opportunity to oil the clutch cable. A little plasticine funnel and bribble some lube into the cable.
Avi8or is offline   Reply With Quote
Old 02-01-2007   #6 (permalink)
Nice tip cheers
Old 02-01-2007   #7 (permalink)
Nope, havin' a pretty good one actually - just busy.
The ones who have problems installing the Pazzos seem to not read the manual.
I like my black Pazzo shorties on the Speed Triple.
Reinstated
Old 02-01-2007   #8 (permalink)
Who doesn't Dev.................
Old 02-01-2007   #9 (permalink)
Done it,no problem
Thanks
Old 02-01-2007   #10 (permalink)
Good.
Did you RTFM? :hammer:
Reinstated
Any PAZZO Levers Install Tips? dblhelx Speed Triple Forum 10 08-28-2007 08:33 AM
brembo / pazzo lever install: zooplancton Speed Triple Forum 7 02-12-2007 03:23 PM
Pazzo Levers Enfield T3 Sport / Touring Forum 3 01-12-2007 01:04 PM
Pazzo Lever Install graciejohn2 Speed Triple Forum 8 10-16-2006 09:09 PM
pazzo f1eric Speed Triple Forum 0 05-13-2006 03:10 PM
