hid kit for 1050 Speed Triple ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-26-2006, 11:00 PM   #1 (permalink)
any sources for a kit , or is generic the only option ?
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Old 12-26-2006, 11:05 PM   #2 (permalink)
don't they make bulbs that plug in for our triples? i'm about 100% sure they do from talking to a guy at the local shop recently.
i want to get that next for speedy. bright = good.
zooplancton is offline   Reply With Quote
Old 12-26-2006, 11:23 PM   #3 (permalink)
i have got the bright bulbs , but they use more amps than stock .
from what i understand the hid , uses less current , offers a much better light pattern and brightness , runs cooler .
i know there are ballasts involved in addition to the bulbs
HURT SMURT !!!
Old 12-27-2006, 12:10 AM   #4 (permalink)
Favourite Bike: 2011 Sprint GT
Other Motorcycle: 70 Commando cafe
You just buy the generic HID kit that has the right bulb. I've put a couple in and have been happy with the results. The biggest problem I've had is finding a place to put the ballast. Not many hiding place up front on the S3. www.xenondepot.com has a motorcycle specific kit with a 6' long lead that should allow you to locate the ballast out of the way.
littlefield is offline   Reply With Quote
Old 12-27-2006, 12:57 AM   #5 (permalink)
I have hid on my 00 speed triple. Easy to install. The blast fits near the gas tank.
But honestly the light is kinda weak, the stock lighting is better, and having the high beam is very handy!
http://www.lusori.com
Cement/stone/brick work in DC/MD/VA
http://www.cycleposers.com
forum for motorcycle idiots, retards and morons
roadkill is offline   Reply With Quote
Old 12-27-2006, 02:50 AM   #6 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
So the HID lights would need a separate bulb for high beam? Or why is the low/high functionality lost?
Martin_R is online now   Reply With Quote
Old 12-27-2006, 04:49 AM   #7 (permalink)
As far as I know, the cars with HIDs have separate low and high beams. The H4s in S3 have two filaments per bulb, aka one for low beam (with reflector) and one for high.
HarriS is offline   Reply With Quote
Old 12-27-2006, 06:55 AM   #8 (permalink)
DEcosse's Avatar
[quote]
HID bulbs are mono so you canot have both beams in a single lens.
You should get much better light intensity from an HID, typically even better than a highbeam. However to get the maximum advantage a projector lens is required & I'm not sure the stock shell is conducive to obtaining the best results from HID.
Maybe a combination upgrade with something like the Adjure shells would be a good combination.
Another fallacy is the temp rating - higher does not meet brighter! The colour changes as you get higher in temp; the brightest (& whitest) will be at ~ 5100K. 6K is more blue & 8K is purple but the actual usable light output is diminished.
One alternative to retain the high beam function (for flash primarily) would be to only change one light to HID.
Edit - I found this kit in a Google search: has an available Bi-Xenon bulb option which is supposed to simulate low/high beam operation. This one has the electronic ballast, there is also a cheaper kit with conventional ballast/igniter set-p. The M/C kits do have extended cables.
I have NO idea how effective the BiXenon would be in our application! They're a bit expensive ($778 for pair for Bi-X & Electronic) to be guinea pig on but certainly look interesting. That does drop to about $500 per pair for the non electronic ballast kit.
Disclaimer: NO affiliation of any kind with this product or vendor or even first-hand knowledge of its effectiveness! Just something that turned up on Google!
[ This message was edited by: DEcosse on 2006-12-27 06:14 ]
T'Rat.net BOTM November 2009
Old 12-27-2006, 08:22 AM   #9 (permalink)
Favourite Bike: '01 Speed Triple
I have the Raybrig Whitesonic bulbs and Hella H4 lenses, and it is a very bright combo.
Speed3 is offline   Reply With Quote
Old 12-27-2006, 10:51 AM   #10 (permalink)
Favourite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Just get a set of these
Seriously, unless you're dead set on spending a lot of money and really enjoy tinkering so that you can find a place for the ballast, get a set of good bulbs and be done with it. I have some PIAA H4s that make a huge difference. They ain't cheap, but they're less than converting to HID.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
I have just ordered a 1050 Speed Triple robnobrakes Speed Triple Forum 6 07-18-2008 10:18 AM
2005 Speed Triple 1050 Chev25250 Speed Triple Forum 9 01-10-2008 10:24 PM
Tool kit for '07 Speed Triple PrettyFunkyPunky Speed Triple Forum 8 12-28-2007 05:49 PM
My 1050 Speed Triple is making way for a........... robnobrakes Speed Triple Forum 6 07-20-2006 06:25 AM
1050 speed triple geordiesas Speed Triple Forum 0 07-16-2005 04:27 AM
