after considering the options , i wanted something that would not come loose and enter the engine , so that ruled out tape and plugs from the inside , i know that worked for a lot of people but it made me nervous
i used a 3/8 socket head cap screw , 1-1/4 under the head and "screwed " it into the outlet hole from the hose side , you kind of have to
cut your own threads while screwing it in , works like aq champ . then for neatness i put the hose back in place with the factory clamp.
if i had used a 1" bolt it would not have protruded into the air box at all
and been completely warranty friendly stealthiness.
i also put a 1/4 inch bolt into the little open air hole on the bottom of the secodary air chamber , it self threaded into the hole and i cotter pinned it from the outside .
just my 2 cents .
HURT SMURT !!!
