The single most important thing is to vary the rpm quite a bit. Picture a nice easy ride on a curvy backroad; rolling on the throttle, shifting through the gears, not just a steady speed. This kind of ride is the best thing I can think of for the break in. Just stay away from big rpm, and wide open throttle for a while and it will be fine. I tend to follow the manufacturers guidelines, albeit a little loosely. Just remember that you can also be too conservative during break in. Basically, there is a "grey area" you want to land in; to little throttle, and the rings may not seat properly; and to much throttle is hard on the bottom end. To much rpm is hard on the valvetrain until it's all bedded in. This satisfies both sides of the fence. Or, just try to blow it up before the warranty expires! :-D
[ This message was edited by: StuckInKansas on 2006-12-23 23:48 ]
I used to ride a Hardley Ableson, and I used to think that was fun.
