BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 12-17-2006   #1 (permalink)
Was in the airbox yesterday to plug off the air injection (SAIF system) which worked by the way. No popping now. AAAAnnnndd, I noticed some greasey looking oil in the lower rear part of the airbox. Not a lot, but just along the back edge. It was obviously coming from the crankcase breather hose. It wasn't real runny like fresh oil, but a little thick. I've got 10K miles on her and all is fine so far. Anyone else noticed any trace at all of oil in theirs? :???:
3forme is offline   Reply With Quote
Old 12-17-2006   #2 (permalink)
I havn't been in there yet, but plan on it. How did you block off the SAI? I've heard of people putting a marble in there, but i'm hesitant ot do that.
Triple_Rider is offline   Reply With Quote
Old 12-18-2006   #3 (permalink)
I had this happen to me once. The jackasses that changed the oil in my v star over filled it and it all went up into my air filter. Just put a little too much oil in and when it got hot it came out the breather.
Nimec2320 is offline   Reply With Quote
Old 12-18-2006   #4 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Some greasy residue is normal. You will get some oily mist rising up the breather even if the bike is not overfilled.
So if the airbox was just a little damp and oily on the surface around breather then you are OK. If there was more than a little of actual fluid in there, then you might want to think about looking into this further.
By the sound of your description I think you should just clean it up and forget about it.
Martin_R is online now   Reply With Quote
Old 12-18-2006   #5 (permalink)
Thanks Martin_R. I will watch the oil level though and make sure I'm not overfilling it. I wish it had an oil level window. It's so much easier and faster that way.
Old 12-18-2006   #6 (permalink)
Triple_Rider, I searched the archives and found that some guys just put duct tape over the hole, so I tried that as my first move. The popping did stop after blocking it! :-D I may later eliminate the whole system. I also taped over the so called 'drain hole' right in the same area. I didn't like having it open to the engine without being filtered.
Oil in the airbox Rustee Club Cafe 5 09-10-2007 10:37 PM
Help! Oil in the airbox. TroyH Club Cafe 10 06-11-2007 09:57 PM
Oil in Airbox Charro Twins Technical Talk 11 02-07-2007 08:13 PM
Airbox & oil sprinter900 T3 Sport / Touring Forum 4 05-18-2006 05:08 PM
Oil leak from airbox voodoo_chile Speed Triple Forum 8 03-20-2006 10:18 AM
