I don't think you have an "electronics" issue, per se. It sounds more like a switch gear issue. Corrosion on the contacts inside the switches, probably. I'd open them up and see. Only takes a phillips head screwdriver. Easy.
In any case, it's a 2006! Take it in to your dealer. Probably they'll fix it under warranty, no questions asked (It doesn't matter that you ride in the rain. This isn't precluded under warranty!)
If they won't, it may be time to find a new dealership.
