BikeBandit
Old 12-15-2006   #1 (permalink)
Favorite Bike: '05 Speed triple
crudmop's Avatar
Other Motorcycle: Current Collection:
Extra Motorcycle: 01 996 -03 636 -98RS 250
I did a weak attempt at a search to see if anyone else had posted this up, but got bored after searching and figured I'd post up anyway.
At around the 15k mark, I started noticing a bit more mushiness in the shock, and though I had it set on "hard", I had to add a turn or 2 to get a bit of the stiffness back. Unfortunately, as time went on, I noticed it was still slowly getting mushier. After a long weekend through some hard riding in vermont, I noticed I had bottomed out against my license plate, and figured it was time to talk to the dealer. At 20k miles, the shock shouldn't be failing, plain and simple.
After running it over to the dealer, he found a servie bulletin warning of possible shock failures, and a possible problem with the lines connecting the resevoir to the shock. 2 weeks later, they warrantied my shock and away I go.
I have an early vin triple, and apparently the later 05 vins were not listed under the service bulletin.
If you notice any sloppiness in the shock, run it in, you might be in line for a new shock.
crudmop is offline   Reply With Quote
Old 12-15-2006   #2 (permalink)
I haven't heard of that one crudmop, thanks for the info man! Might have mine checked out. So got any long trips planned this year? :wink: :-D
cheapbastard is offline   Reply With Quote
Old 12-15-2006   #3 (permalink)
So what was the problem with your shock? The line leaked and as the shock de-pressurized it stopped damping altogether?
Martin_R is offline   Reply With Quote
Old 12-15-2006   #4 (permalink)
crudmop's Avatar
Nope - I saw no leaks around the shock or resevoir, and the shock held pressure throughout riding. I've had a Sachs go south on me mid ride on my Falco, and I didn't get any of the telltale bouncing of a shock that has no nitrogen left
It started feeling a bit mushy, and wallowed around in the corners more than it should have. Under hard riding, it was apparently failing under heat.
I am not sure what the bulletin said, as I never saw it - my dealer is in the middle of rebuilding and the place is a mess, so he wasn't in a position to pull out the paperwork.
[ This message was edited by: crudmop on 2006-12-15 14:01 ]
Old 12-15-2006   #5 (permalink)
Hey Crud, how you doin'? Good to see you back.
I've got an early Vin 05. I'll check with the dealer. Going in for my 20,000k service just after Christmas. Good thing we have the 2 year warranty.
As Cheap asked, have you done any more long trips. We'd all like to hear about it. Make a nice change from all the meaningless drivel from the post ho's around this site. :-D
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 12-18-2006   #6 (permalink)
crudmop's Avatar
Howdy, Leggy! Yeah, I've been a bit absent from this board, as some of the posts can get a bit, shall we say, ugh!ish
Unfortunately, no real trips this year - ran down to the Gap once, a few trips to WV, and a handful up to VT/NH. We have a 5yr old, and just couldn't get a lot of time away this summer. A friend came in from the UK for 2 weeks, which pretty much killed the window for the trip up to PEI, so we didn't get to go anywhere. Alas.
How about you?
New Saftey Recall Service Bulletin # 386 famonterojr Modifications & Workshop Talk 1 09-27-2007 04:14 PM
FYI Service Bulletin 07 Daytona CrazyDave Daytona675 Forum 1 08-28-2007 11:17 AM
Sprag clutch service bulletin?? shagdog1976 Hinckley Classic Triples 7 11-30-2005 05:12 PM
Service Bulletin Mr_Chips Modifications & Workshop Talk 0 10-28-2005 05:24 PM
