Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 12-14-2006   #1 (permalink)
i got the manual , but for the life of me i cant find the stock suspension settings .
i know i saw them around here but i can t find them with search
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Old 12-14-2006   #2 (permalink)
Limited Access
think they ones quoted in this thread are stock settings.Click.
Limey is offline   Reply With Quote
Old 12-15-2006   #3 (permalink)
With your brakes like that, why play with suspension settings??? :???:
It's cold outside and we just missed the bus.
MrZed is offline   Reply With Quote
Old 12-15-2006   #4 (permalink)
I can't get the chart to paste in here but this is the text:
The five numbers correspond as follows:
1 FRONT Spring Pre-Load
2 FRONT Rebound Damping
3 FRONT Compression Damping
4 REAR Rebound Damping
5 REAR Compression Damping
Solo Riding Standard 3.00 2.00 2.00 2.00 2.00
Solo Riding Softer 3.00 2.50 2.50 2.50 2.50
Solo Riding Firmer 3.00 1.50 1.50 1.50 1.50
Rider and Passenger 3.00 2.00 1.50 0.75 0.75
* Number of adjuster turns out from the fully screwed in position.
There is no rear pre-load suggestion due to their head-in-ass assertion that it is not adjustable. I think mine had 5 threads above the lock ring in the stock setting.
dr_gallup is offline   Reply With Quote
Old 12-15-2006   #5 (permalink)
Limited Access
I'm a little confused on the front pre-load. is it 3 turns from fully in or is it 3 lines showing. :???:
Old 12-15-2006   #6 (permalink)
The chart says "Number of adjuster turns out from the fully screwed in position" but the section on adjusting says:
Spring Pre-Load Adjustment
– Both Models
The spring pre-load adjusters are
located at the top of each fork.
To change the spring pre-load,
rotate the adjuster clockwise to
increase pre-load, or anti-clockwise
to decrease pre-load. Always set the
pre-load adjusters such that there
are an equal number of graduation
lines visible on both forks.
NOTE
• The Daytona is delivered
from the factory with the
spring pre-load set at
position 5, the Speed Triple
at position 3.
I think they mean 3 lines.
Old 12-15-2006   #7 (permalink)
Limited Access
Thank You.
Old 12-15-2006   #8 (permalink)
zed , my brakes are fine , thank mr. suzuki gsxr 1000
glad your happy with yours , i need something a little more consistent
myself
HURT SMURT !!!
Old 12-15-2006   #9 (permalink)
got mine set at
front preload 2.5 lines ( set with a depth mike to get the same
rear preload 5 threads showing , was three had to jack it up
this corrected lots of the wallowing
rebound and compression at at 1.5 turns out front and rear
probably going to lower the front preload to 3 lines , it feels a little light
in the hands
also going to try setting the forks even with the top of the triple clamps
mine are about 1/8 of inch above the clamps
HURT SMURT !!!
Suspension Settings. Brooksie Daytona675 Forum 7 01-16-2008 07:38 PM
suspension settings ricster Sprint Forum 4 07-01-2007 07:01 AM
Looking for Stock suspension settings 02 S3 Tridolph Speed Triple Forum 4 04-07-2007 12:08 AM
suspension settings for two-up... dml955i Speed Triple Forum 1 06-17-2004 06:15 PM
Suspension Settings yellowTBS Hinckley Classic Triples 1 05-30-2004 02:00 PM
