BikeBandit
Old 12-11-2006   #1 (permalink)
Limited Access
Thanks in advance. :-D
Limey is offline   Reply With Quote
Old 12-11-2006   #2 (permalink)
Favorite Bike: '01 S3
2bugeyez's Avatar
Other Motorcycle: lookin for my '96 T-bird
Should be 46mm. Had to order my socket online. Kinda hard to come by in the stores.
Speed thrills!
2bugeyez is offline   Reply With Quote
Old 12-11-2006   #3 (permalink)
Favorite Bike: '01 Speed Triple
I got my 46mm from Triumph. 1/2 in drive. 108 Ft. lbs to tighten.
Speed3 is offline   Reply With Quote
Old 12-11-2006   #4 (permalink)
Here!
AlaskaS3 is offline   Reply With Quote
Old 12-11-2006   #5 (permalink)
Limited Access
Thanks guys. I'm lucky enough to have a tool shop down the street that sell pretty much any tool thats ever been made.
Got to replace the rear tire again. #7. Found her in the garage this morning flat with a nail in it, thank god it was shagged anyway, not like the last one that blew after a couple hundred miles.
Old 12-11-2006   #6 (permalink)
i found a screw in my tire about 500 miles ago. i plugged the sucker and haven't had a single problem.
tekmoe is offline   Reply With Quote
Old 12-12-2006   #7 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
Seven tires in how many miles?
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
Old 12-12-2006   #8 (permalink)
Geez, Limey you gotta stop riding through building sites. You sure are having bad luck with tires. :???:
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 12-12-2006   #9 (permalink)
Another option is to go to an auto supply shop that has free tool rental. I went Auto Zone and borrowed one. They charge a deposit but refund it in full when you return it.
"If you don't know where you're going, any road will get you there"
Sharpy is offline   Reply With Quote
Old 12-12-2006   #10 (permalink)
Favorite Bike: 2006 Triumph 955i Daytona
Other Motorcycle: BMW R1150RT (Biarritz Blu
Extra Motorcycle: 1996 Laverda 668 Formula
Never mind the wheel nut, what the hell size is that big mother that holds the front sprocket on?
Does anyone have the technique for replacing the front sprocket with a smaller one ( like how do you hold the bike whilst you undo the humungeous nut, stop the rear wheel turning, etc etc)
Any suggestions (clean) appreciated.
Linz :-)
Linz is offline   Reply With Quote
Rear Wheel Removal - size of nut 45mm? geelongrat Sprint Forum 12 02-22-2008 08:32 PM
Rear wheel nut size, 02 Sprint RS sjestory Sprint Forum 3 01-18-2006 11:06 AM
Rear wheel nut size,00 Sprint ST? Dirtybill Sprint Forum 4 01-18-2006 12:16 AM
rear wheel nut size bernie Sprint Forum 6 08-27-2004 09:36 AM
Rear Wheel Nut Size??? nyspeedtriple Speed Triple Forum 3 08-03-2004 03:02 AM
