Old 12-05-2006   #1 (permalink)
I took to my S3 seat on the weekend and chopped 1 inch out of it - as was explained on one of the posts. I can now place the balls of both my feet on the ground and in my opinion is more comfortable than before.
Now I need to know which set of Renthal bars to put on it, I went to an accessories shop and they have a dozen different types of bars. What I would like is the same style (reach - position) of bar thats on the bike now but 1 inch higher. Has anyone got a Renthal part number?
Cheers
Trumpy1050 is offline   Reply With Quote
Old 12-05-2006   #2 (permalink)
Does triumph maybe sell some risers?
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 12-05-2006   #3 (permalink)
Cool - do they interfere with the gear shift?? :-D :-D :-D
oldmanrandall is offline   Reply With Quote
Old 12-05-2006   #4 (permalink)
If you want one inch higher DO NOT get the Renthal streetfighter bars as they are pretty close to the stock bar size. Also keep in mind that if you go an inch higher you might need to change the front brake line.
Avi8or is offline   Reply With Quote
Old 12-05-2006   #5 (permalink)
If you go 1 inch higher, You will absolutely need new brake lines.
I put Renthal street fighter bars on mine and needed to bend the banjo at the M/C so it would not pop out of the fender clips, It may have been due to the width being a half inch wider.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 12-05-2006   #6 (permalink)
How did you do that mate, or where is the relevant post?
I need to do lower mine too.
Mulcahey is offline   Reply With Quote
Old 12-05-2006   #7 (permalink)
do you mind me asking how tall/short you are? I'm 5'4" (~160 - 165cm), and I'm installing the Hagon short shock, which is supposed to drop the seat height by 2" (50mm), I'm hoping it'll be enough to get the balls of both feet on the ground.
Thanks,
Jonty
JontyG is offline   Reply With Quote
Old 12-05-2006   #8 (permalink)
You can always chop a half inch off the bottom tubes of the rear subframe. That'll drop the arse-end quite a bit and lower seat height while keeping the suspension geometry the same. Might be something I'll do when I get the frame and subframe coated black. We did it to my dad's SV1000 project bike and it worked beautifully for lowering the tail.
Old 12-05-2006   #9 (permalink)
Oh, but you'll need to have the equipment and knowledge to weld aluminum...
Old 12-05-2006   #10 (permalink)
Check the "higher bars" posting on page 5
AA
amberale is offline   Reply With Quote
replaced coolant - didn't reach 2.64 quarts txsport06 Triumph SuperSports 3 06-08-2007 12:14 AM
adjusting throttle play - how the hell to reach the adjusters jpeake Speed Triple Forum 10 05-09-2007 08:21 PM
Help with skyking slider install? Can't reach rear bolt mperetz Speed Triple Forum 17 04-19-2007 11:42 PM
coolant on the ground legend Hinckley Classic Triples 6 04-15-2007 11:45 AM
My carbs won't reach the airbox! JEB Twins Talk 3 04-13-2007 04:01 PM
