Your liner will come with a female dongle that wires directly to the battery (or how I did it, to a solenoid activated by a switch on the bars.) The dongle just hangs down inside the body work so you can plug it into the liner's male dongle. When not in use it's easy to tuck up under out of the way. The liner's wire comes out at the left side waist.
This works well, because if you forget to unplug before getting off the bike they just pull apart. No breakage or tripping.
All the parts are very high quality, and if you wish you can mount a heat controller either permenantly to the bike or somewhere on the jacket.
Sorry I don't have any pictures, but my bikes all torn down right now.
[ This message was edited by: crashmasterd on 2006-12-01 19:31 ]
