Old 11-29-2006   #1 (permalink)
Hello, I've done some searching on here but have not seen what I'm looking for. I mostly do straight line commuting on my S3 with the occasional twisty. I'm looking to replace the stockers does anyone have any recommendations and where to buy? Also the dealer quoted me a install labor charge of around 175.00 does that sound right?
Appreciate the info...
2003 S3
Skyking Bar Ends
Skyking Frame Sliders
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Razorback_Fan is offline   Reply With Quote
Old 11-29-2006   #2 (permalink)
That sounds very high, to me. I change my own tires, but, I think most places here charge about $20/tire if you take them the wheels and $40/tire if you ride the bike in to the shop. I'd suggest you go to a shop that sells a lot of tires, rather than a Triumph dealer.
Curmudgeon is offline   Reply With Quote
Old 11-29-2006   #3 (permalink)
MotT3's Avatar
Metz Z6 don't square off too quick and still handle...I've had a few sets and still coming back for more :wink:
www.mottleybiker.com
MotT3 is offline   Reply With Quote
Old 11-29-2006   #4 (permalink)
Surely that price includes the tire!!! Have you tried the Continental Road Attack's yet? I can't vouch for 'em, cause I ain't tried 'em, but I've heard great things about 'em! :-D
cheapbastard is offline   Reply With Quote
Old 11-29-2006   #5 (permalink)
Avon Azaro 45/46 ST. I've got almost 3K on mine and they still look and grip like brand new. I ride mostly twisties with about an hour of straight line freeway riding to get there.
I don't push her too hard, but I'm expecting to get 8-10K out of this set...
They're not cheap, but they are great tires...
dml955i is offline   Reply With Quote
Old 11-29-2006   #6 (permalink)
I like the Pirelli Corsa lll much better than the Michelin's, But, $175. to change the tires out sounds outrageous!
For that kind of money you can just about buy all the tools needed to remove your own tires.
There is a rear stand on ebay in the Triumph section for around $80
If you decide to remove your own rear wheel, Remember, It takes a lot of @ss to break that big nut loose, I had my girl sit on the bike while it was on the floor and hold the rear brake while I broke it loose with an extension on my breaker bar, That was the hardest part.
The front, I used a floor jack, shimmed in places with s***** wood so I didn't crush the headers... Keep it on the rear stand to keep the bike vertical.
At first on the front, I used a standard sport bike rear stand with the rubber swing arm lift pads pushed in close enough to lift at the front brake caliper brackets, worked great at first but the forks got twisted on re-assembly and I couldn't get the axle back in, So I went to a floor jack to get the front wheel back on.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 11-29-2006   #7 (permalink)
Thanks for the opinions so far
The dealer quoted me 70 an hour as the labor rate One hour for the front and one and a half for the rear.
I can't locate the Conti's anywhere online the dealer quoted me 180.00 rear and 130 for the front on those.
I look into the others mentioned.
I take apride in doing my own work but I would rather have this done.
2003 S3
Skyking Bar Ends
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Old 11-29-2006   #8 (permalink)
***** can't edit my post...I sound like I'm still in Pre-K
2003 S3
Skyking Bar Ends
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Old 11-29-2006   #9 (permalink)
The dealer's trying to bend you over. Those time estimates are absurd. Also, they're backwards; it takes less time to change the rear than the front.
Old 11-29-2006   #10 (permalink)
scratch's Avatar
So far, I've tried BT020, D220, Metzler Z6 and Michelin Pilot Roads in the "sport-touring" category, and they all seem to wear and handle about the same. The Pilot Roads turn in a little slower because of their more rounded profile, but it wasn't a bad thing really, just different.
Since you're in the Woodlands, you might consider dropping your wheels off at Cycle Gear on I-45 near West Road. Their prices are significantly better than what you were quoted and they only charge 20$ to mount and balance, but your wheels do have to be off the bike.
2004 Speed Triple SE
scratch is offline   Reply With Quote
Looking for a sport touring picture Max_NYC Speed Triple Forum 8 08-31-2007 09:29 PM
Sport Touring for Dummies Alsworld Ride / Trip Reports 14 12-08-2006 11:27 PM
Sport Touring On A Thruxton In The UK Orson Club Cafe 23 05-05-2005 02:32 PM
tire recommendations of the sport-touring variety? redsled Speed Triple Forum 14 01-25-2005 07:03 PM
1200 For 2 up Sport Touring 99d12 Daytona Deliberations 3 07-14-2004 01:29 PM
